Rear end loader!
/ Rear end loader! #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
Some of you may have seen this before but it is a new one on me. It may be junk..it may be great. But it is interesting. A full loader style bucket for the rear of a tractor. Could be a handy econimcal alternative to a FEL for those who really don't use one often.
http://www.compacttractorconnection.com/loadmore_frame.htm
/ Rear end loader!
/ Rear end loader! #5
I would think that with out down pressure it wouldn't be as easy to use as a front bucket, or as fast
also I don't think my tractor can push backward with as much power as it can in forward
/ Rear end loader! #6
/ Rear end loader! #7
One of the biggest problems that I can think of right away is the fact that the 3 point lift arms have much more strength pulling as they were engineered to do rather than pushing. There have been more than a couple TBN members that have bent or otherwise damaged their lower lift arms while pushing with a box blade or a rear blade.
/ Rear end loader! #8
/ Rear end loader! #9
I really like my dirt scoop.
One of my ideas I would like to design is like a dirt scoop,
only it would lift up higher, then flip over backwards to dump.
If it could lift up and back, you could dump onto a low trailer.
I have moved a lot of dirt with my scoop.
But it takes 6 trips to make 1 yard of dirt.
With gas costing so much I could just order a truckload for the same cost.
And save wear and tear on the tractor.
But if I could fill up a small trailer then tow it up here and dump it,
then that would help a lot.
Right now if I want dirt I drive down to the lower end of the property
and scoop up a load and bring it back. I do about a yard and a half per hour.
Pooh Bear
/ Rear end loader! #10
Pooh Bear
/ Rear end loader! #11
I'll go along with you, the pond scoop is a handy device. Especially after I learned to use it efficiently. I've wondered about mounting it on one of the scissors lifts you see for bale spears. Maybe this coming winter. /forums/images/graemlins/tongue.gif
/ Rear end loader! #12
/ Rear end loader! #13
I think a rear loader may be more effective than a front loader on a 2wd tractor, especially if it lacks power steering. A front loader causes a loss of traction and more difficult steering as it is loaded while traction actually increases as a rear loader is loaded. I made one out of a pond scoop and a lift boom attached to the upper 3-pt attach. Stabilizer bars were added to the lower links which were extended with angle iron to reach the lower 3-pt attach of the scoop. A fair ammount of hydraulic power is required to operate such a device as a lot of leverage is lost with the extended scoop. My Ford 2000 had plenty but the little 8n could only lift the empty scoop. I loaded a lot of trucks, trailers and manure spreaders with this setup before going to a fwd with power-steering and front loader. I would rate the rear loader on the 2wd about 1/2 as effective as the front loader on the fwd but it cost less than 1/10 so depending on the ammount of loading you need to do it may be an economical alternative.
/ Rear end loader! #14
/ Rear end loader!
I was thinking it would be good at soft, loose materials. And it would be a lot cheaper. I have a fwd with ps and a fel, but I might economize on my next( if there ever is a next) tractor. I really don't use the loader much except to move gravel and dirt, most of my use is mowing and scraping.
/ Rear end loader!
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
New Holland T5070 (A64126)
New Holland T5070...
John Deere 348 Square Baler (A65579)
John Deere 348...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
Kubota L2501 (A62177)
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
