DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,670
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
As for the shaft not sliding out. Probably the weight of the diffy hanging on the shaft may have it binding. I do recall in the manual, about not taking both carriers out at the same time, as it will let the differential drop.
As for cleaning, again up to you. I've used diesel to flush housings. More than several cans of carb. or brake cleaner. Brake cleaner flashes off quick, and leaves no residue. I've got a pressurized spray can that holds about 1 1/2 quarts for jobs like this. Maybe a squirt bottle of some kind would work, if you were able to turn the bearings, while applying what ever solvent you decide on. Maybe something like that first, then final cleanup with brake cleaner..??
