rear end brake problems
/ rear end brake problems #1
tomcase580b
manorville
case 580b
I have a mid 70's case 580 b ck. Today while moving some heavy wet sand, i hear a pop come from the left side rear. At this point i lost drive in that wheel?nd brakes. The only way I was able to limp my way home was to use the plunger pedal which I use when I get wheel slip and lose traction. I am no mechanic, so forgive me with the terminology I'm using. Can someone tell me what I broke from the description I gave.
Thanks
Here is an update. It's the differential lock pedal that I was pressing when i was getting wheel slip. The manual I have said make sure rear wheels are not spinning when depressing the diff pedal. I was also probably pressing the clutch / brake pedal at the same time which is also a no no… so this makes sense that I have no brakes…. I'm thinking I did some serious damage in the gear box ...
/ rear end brake problems #3
Could be anything from a broken axle, to items back to the bull pinion shaft. Here is a link to Case Construction parts to the 580B power train assy's. Official Case Construction Equipment Online Parts Store and Parts Look Up. Parts for Case Equipment and Construction Equipment. Parts Store for Case Wheel Loaders, Case Excavators, Case Skid Steers, Case Original Parts. Click on power train, and it will open to the different components.
Did you try feathering the left brake to try and make it move..?? If the bull pinion shaft is still intact, I'm thinking applying the left brake should make it power out to the right side. You may want to try that, and if it moves, you may have snapped an axle. Even at that, you'll need to remove the top off the diffy, to get to the nut on the end of the axle to remove it.
While you're at it, you may want to take a look at the differential lock. IIRC, they are made of aluminum, or pot metal, and I think the purpose was to be the weak link, but seldom is... I had a buddy let some younger guys plow with his JD 4020 while he took a break for supper. He was gone 45 minutes, and the boy managed to tear the ring & pinion out, doing the same thing.
Hope you have a service manual, I do believe you're going to need it.
Yeah I do have a service Manual…I believe this is above my pay grade
/ rear end brake problems #5
Gotta' learn sometime...
/ rear end brake problems #6
If it's an OEM manual like the one for my 480C, they are very descriptive, and take you though step by step. If you got the place, and the tools to work on it, go for it...
I have a parts catalog that is like two telephone books?really helpful?ut I do not have a service manual. I have the room…the tools I don't have I will buy or borrow…can you tell me where you got your service manual? I'm thinking I'll need one for this fix.
Thanks
/ rear end brake problems #8
I got mine off epay, apparently when someone wasn't looking, or needing one. I just checked, and there are 3 hard copy's, but are @ $189.00 (ouch..) However, there are several on CD for $10.00 to $16.00. Never used one of those, so have no idea of the quality.
Most everything I've worked on, on my 480C, a standard mechanics set of tools did the job. Although the impact wrench, and small butterfly air wrench sped up tear down. I'm guessing the axle nut, if it needs removed may be the largest socket needed, and something in a 3/4 set will be needed. Plus a torque wrench to put it back together.
ok...I ordered a manual online... should have it in a few days...Last night I was able to get the machine up on the cement pad back by my garage, so it's in a good spot right next to the tools. I was able to move it by pressing down on the differential lock and using the right tire to get traction. The brakes for the right tire also work. However I have no braking ability for the main drive tire and she does not spin. I should clarify that. it spins kinda goes a little in the same direction as the other wheel when I have the outriggers down and the tires in the air, but nothing that would move the tractor.I think I'm starting to understand how the rear axle and differential work... I got a buddy at work that is a master mechanic that said he'll help...I'm thinking I want to tackle myself though...Thanks for the help DJ54...I'll let you know how it goes.
/ rear end brake problems #10
Does it just have a ROPS, or complete cab..?? Mine has a ROPS... I removed the right fender, tire & wheel from the side I needed to get into, and removed the floor panel(s). Held that side of the ROPS up with a chain hoist, plus an extra chain up to the I-beam across the shop as a double safety. Makes it so much easier to get to what you need to work on.
I didn't need to pull the top off the diffy though. Just reworking the brake assy's, and replaced the lines. Just made it a whole lot easier for a guy my age & size...
Do take some pics along the way, we LOVE pics..!! And sometimes help when going back together, LOL...
Best of luck..!!
DJ can you tell me if that pin on the outrigger is a locking pin that I can keep the outriggers locked in place while taking the wheel off by moving the pin to the opposite hole?
/ rear end brake problems #12
Couldn't say it is, or isn't. My 480C isn't like that as far as a pin keeper. Mine has snap rings holding the pin in place.
What I did, was cribbed up under the bracket with large wooden blocking the pin goes through, then folded the outrigger back up out of the way.
Hey DJ54…thanks for inspiring me…I got a set of 6 ton jack stands and some air tools and started stripping her down tonight. this is what I found when I got the top cover off the diff. I'm really happy it's not the axel. but it looks like i have alot of work ahead of me. I'm going to wait for the service manual now. I believe that is the differential gear assembly thats shredded...
/ rear end brake problems #14
Looks like the bull pinion shaft/gear. I did some checking around the other evening, and found this one on epay: New Case A144337 Side Gear Fits 580B 580CK 430 530 480C | eBay IF it happens to be the right one. After market I'm sure, but Case Construction price is $499.00.
Now is when you need your parts manual, to check the part numbers, or check the part number(s) online. I just checked Case Construction, and I believe that pieces part number has been superceded to a couple others.
Also, if you want to check, or need any other parts, check here: Remanufactured Transmissions, Torque Converters, Engines - Joseph Industries They beat everyone hands down at the time I needed parts for mine. No prices listed on a lot of items, you just need to call. You'll more then likely be talking with Bill Pingley. Or ask for him, he knows his stuff..!! Tell him Dave J., from Carroll, OH sent you.
Good luck..!!
DJ...I hate to be a pain?o you have any idea how to get the axel out. I removed the castle nut and cotter pin but the axel only comes out a half inch?o I need a puller??'m so close...
just watched a you tube video of a guy removing the same axel…he beat it with a lump hammer…guess ima gunna do the same
/ rear end brake problems #17
Oops..., sorry just saw this... Hope you got it out..!!
Got it out with two whacks!!!
Ok so here is what I found. When fishing out and counting all of the broken teeth (13). I found the head of one of the bolts that hold the ring gear assembly together. (See Pic) It looks as though this could have been the original problem. I don't know what could have caused that head to snap off...Maybe a broken tooth, but it clearly has a tooth mark through it. (See Pic) I really do not want to take the brakes off the other side and remove the ring gear assembly. I dont think I can get it out from the side that I have off because the shaft is too long and needs to be pushed to the other side to allow the ring gear to come off. I'm sure I'll be ok with the one bolt missing, but half of it is still in there. not sure if that will wiggle its way out one day and the same thing happen all over again. Heres my thinking? If dont have to take the carrier assembly off of the other side, and all I have to do is take the cover assembly off to slide the shaft over, I'll do that. I had one heck of a time getting the carrier assembly off of the side i was working on, and snapped the 7/32 allen head set screw . Do you think that taking the cover off is all i have to do? And which is the part that I need to order 8 or 11 I'm thinking 11 bolthead1.jpggear1.jpgdiagram1.jpg
I can't get the shaft to slide free from the ring gear…seems from the diagram that it should slide out. there is about an 1/8 inch play but no go..I really wanted to get the ring gear out and parts wash everything. I'm thinking wash everything in the housing. any ideas on how I can succesfully make a home made parts washer and get all those teeth clean from dirt and little metal pieces.
/ rear end brake problems #20
Hopefully, these pages/pics out of my manual will help. It does appear to remove the diffy, both side will need to come out/off.
As far as which shaft to get, it say's which shaft for a certain side (whether L or R) in the parts description. I do belive #11 is the one I found on ebay for $100.00. Up to you to decide if you want to trust an aftermarket part here. From checking Case Construction, theirs are $499.00.
I'm guessing that bolt backed out of the ring gear. Possibly, progressively cutting that groove in there. There is to be thread locker on those bolts to prevent that. Whether a PO, or possibly someone else working on it previously missed it, or missed when assembled at the factory.
Is the bolt sheared off even, or flush with the face of the gear..?? I'm thinking it may not be that hard to back on out. This is where a set of left hand drill bits come in handy. Sometimes just drilling will turn them out. Regular bits, and an easy-out should get it. A LOT depends on if, and how much it sideways mushroomed, or distorted the bolt. Most I've dealt with, the shoulder on the bolt is a snug fit, so there actually shouldn't be too much distortion. But there has been some serious hammering going on there. If you do manage to get it out, it should be progressively torqued to a final 55 ft. lbs. Go, 30, 40, then 55 ft. lbs.
Next question is, if the diffy is removed, will a dial indicator be needed to set the backlash in the ring & pinion. It does show it being done on back a ways, but that is completely rebuilding the diffy assy. Just hope you kept all the shims in their proper place..!!
Also note you'll need #12, which is a cup plug. Looks to be $13.75 at Case, & $5.00 aftermarket.
I used the advanced feature to load the pics, and it took me away from the thread, to read back. So will load this so as not to lose it, LOL...
