Rear Drip Problem
/ Rear Drip Problem #1
corey
Wellsburg, WV
JINMA 284 LE & YANMAR 240 D
I was cutting a food plot this month in the afternoon with temps well in the 90's and high humidity.
Turning regularly in the tractor seat, to check behind on the brush hog working, I noticed wet streaks on the inside of the LEFT rear ag tire. The rear tires are not liquid filled so first thought was that the marks might be from high wet grass. Quick visual check on the inside RIGHT tire, NO streaks. Disengaged the PTO and slowly drove from the field to the garage. Shut down the 284LE (very nice machine, delivered 10-04, about 145 hours) dismounted and got a better look. The streaks were oil like to the touch. Could not see a source. All metal on the rear end was dry and pollen/dust covered. Put down a cardboard square on the ground with one side all the way to the left tire tread and went to get an ice coffee.
Came back in less than ten minutes and saw a drip of fluid on the cardboard directly under the brass zerk that is on the rear of the left drive shaft housing. Needed to wait for many minutes for the next drip to slowly energe from the nipple of the zerk and drip to the cardboard below.
Source identified. Brass zerk replaced. No more drip. Problem resolved.
However, when the brass zerk was removed the fluid coming from the opening flows and feels like tranny fluid. Never greased this zerk or the one on the right shaft housing because the manual depicts the shaft housing connecting to transmission housing without a seal to prevent tranny fluid from flowing into the shaft housing.
If I am correct in assuming that the shaft housing is filled with 85 W 90 tranny fluid, why put a zerk on the right and left shaft housing instead of a plug ??
Comments appreciated,
corey
/ Rear Drip Problem #2
What make tractor do you have? Couldn't tell from the 284LE?
John
/ Rear Drip Problem #3
Yes, 80W90 is typical for cool to moderate climates. If you're talking about zerk 150, it's the grease path to bearing 154. Your gear oil is probably seeping past oil seal 146 (part #GB/T9877.1-1988). But I'm thinkin' any FB55x75x12 should work
//greg//
/ Rear Drip Problem
John,
The tractor is a JINMA 284LE manufactured 03-04 and delivered here 10-04.
It is used for light work, field plot brush hog cutting and garden tilling.
Greg,
Thanks again for your feedback and attachment.
A recent post appeared on CTOA ,"greasy question". It is also directed to these zerks. The author RonJ has not experienced a zerk drip.
corey
/ Rear Drip Problem #5
A recent post appeared on CTOA said:
If and when oil is coming out the end of a grease zerk usually means the spring loaded ball in the end is damged [not sealing].
For gear oil to come out .... there has to a bad seal.
As the axle tube gets filled with gear oil due to the bad seal .... remember that the level needs to be keep full via the dip stick.
Ronald
Ranch Hand Supply
/ Rear Drip Problem
Ronald
Thank you for the reminder on the fluid level check.
Also want to thank you for the "inner" detail Jinma pics on your website.
I appreciate those pics and also suspect that many other Jinma owners find them useful as well.
corey
/ Rear Drip Problem #7
this is off topic, but would like to thank ranch hand for his great website. i know i have spent hours on his and johns website using up their bandwidth, not there has been any thing wrong with my 284 it is that i am total gearhead and want know how my tractor works
thank you
/ Rear Drip Problem #8
thank you
You are welcome jinmalover ......... help yourself !
Ronald
Ranch Hand Supply
2022 EZ-GO ELITE...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
4022CFL (A59228)
4022CFL (A59228)
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
