Rear Discharge Deck & Blowback of Dry Grass
   / Rear Discharge Deck & Blowback of Dry Grass #1
arto98607
Southwest WA
Kubota F3060, Grasshopper 721D, Ford 1310, John Deere 440 ICD, John Deere 300 & 430
This was really not an issue as long as the grass was green, but for the last month or close to two it's been bone dry and brown, however we still need to mow due to weeds growing.
Has anyone here installed rubber "mudflap" or skirting in the rear edge of this type of deck in order to control bone dry clippings flying back?
Looks like it should be pretty easy to install one.
The factory deck leaves 6 - 8" high, close to full 72" wide opening.
(I have Gator blades which are pretty aggressive)
Anyone who has done it, could you please tell us if it was worth the effort?
   / Rear Discharge Deck & Blowback of Dry Grass #2
My only concern would be the width of "mudflap" so blades don't hit it when in reverse also mowing wet/soggy ground.
   / Rear Discharge Deck & Blowback of Dry Grass #3
Thomas hit the nail on the head. I tried a piece of chain link fence across the back of my deck. It worked to prevent stuff from flying out the back but if the tractor was backed with the deck lowered it would push into the blade. I removed it - not worth the hassle. I'll take my chances with whatever projectiles are thrown to the rear. It's been without the guard for fifteen years now with no problems noted.
   / Rear Discharge Deck & Blowback of Dry Grass #4
Suspend a rubber flap between the front wheels of your F3060 to hang like a curtain.
Use mudflap rubber with the corded reinforcement, not pure rubber sheet,
Use steel plate strips either side to sandwich the rubber and prevent tearing.
The burnt paint on the RH spindle pulley implies that blade was 'stopped' for a time.
   / Rear Discharge Deck & Blowback of Dry Grass #5
I even have a problem with the leading edge of the deck blowing clippings back on me.
   / Rear Discharge Deck & Blowback of Dry Grass #6
My rear discharge finish mower has a chain curtain like on rotary cutters that helps. Switching to low lift blades may help.
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2014 Make...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
2016 CHEVROLET SIVERADO 4X4 PICKUP (A52577)
2016 CHEVROLET...
2021 Isuzu NRR Heil 9Yd Rear Loader Garbage Truck (A50323)
2021 Isuzu NRR...
