Rear crank seal
   / Rear crank seal #1
Fornshell
JD2240
Hey TX Jim, Having a issue with my 2240 rear crank seal. It had a national oil seal in it, rubber lip seal. Installed a JD seal wear ring seal combination and it still leaks, crank journal looked good. Any ideas
   / Rear crank seal #2
You need a spesial tool to instal them to the correct depth
   / Rear crank seal #3
Ditto what DLTrekkers stated
   / Rear crank seal
I used the special tool , was unsure if you put oil on seal or installed dry.
   / Rear crank seal #5
I always put light coating of oil on the lip. Avoid cutting the lip if at all possible.
   / Rear crank seal
Is there any old school techs out there. That can tell me if you put oil on a JD Teflon rear crank seal on a 2240. Would appreciate this info
Best 30' Grain Drill (A50514)
Best 30' Grain...
John Deere 9450 Combine (A50514)
John Deere 9450...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
Cattle Chute (A50515)
2014 Dodge 5500 4X4 Bucket Truck (A52128)
2014 Dodge 5500...
