Rear crank seal
   / Rear crank seal #1
Fornshell
JD2240
Hey TX Jim, Having a issue with my 2240 rear crank seal. It had a national oil seal in it, rubber lip seal. Installed a JD seal wear ring seal combination and it still leaks, crank journal looked good. Any ideas
   / Rear crank seal #2
You need a spesial tool to instal them to the correct depth
   / Rear crank seal #3
Ditto what DLTrekkers stated
   / Rear crank seal
I used the special tool , was unsure if you put oil on seal or installed dry.
   / Rear crank seal #5
I always put light coating of oil on the lip. Avoid cutting the lip if at all possible.
   / Rear crank seal
Is there any old school techs out there. That can tell me if you put oil on a JD Teflon rear crank seal on a 2240. Would appreciate this info
Rhino 484 84in Rotary Cutter (A50322)
Rhino 484 84in...
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
2022 30ft 20k Blazer Deck-Over Trailer (A52128)
2022 30ft 20k...
2016 TRAIL-EZE TE80HT 102" X 48' STEP DECK TRAILER (A51243)
2016 TRAIL-EZE...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
