Rear crank seal
   / Rear crank seal #1
Fornshell
Bronze Member
JD2240
Hey TX Jim, Having a issue with my 2240 rear crank seal. It had a national oil seal in it, rubber lip seal. Installed a JD seal wear ring seal combination and it still leaks, crank journal looked good. Any ideas
   / Rear crank seal #2
You need a spesial tool to instal them to the correct depth
   / Rear crank seal #3
Ditto what DLTrekkers stated
   / Rear crank seal
I used the special tool , was unsure if you put oil on seal or installed dry.
   / Rear crank seal #5
I always put light coating of oil on the lip. Avoid cutting the lip if at all possible.
   / Rear crank seal
Is there any old school techs out there. That can tell me if you put oil on a JD Teflon rear crank seal on a 2240. Would appreciate this info
2024 Dodge Durango SXT AWD SUV (A48082)
2024 Dodge Durango...
2023 Chevrolet Tahoe SUV (A48082)
2023 Chevrolet...
2013 Ford F-750 Truck, VIN # 3FRNF7FC5DV788031 (A48836)
2013 Ford F-750...
2022 Club Car...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2014 Freightliner 114SD T/A McNeilus 2513 25Yd Rear Loader Garbage Truck (A48081)
2014 Freightliner...
