Rear Blade
/ Rear Blade #1
kcook
Platinum Member
MI
Cub Lawn Tractor
How big of rear blade for a CK20S Hydro. THis will be used for moving snow and dirt.
KC
/ Rear Blade
I'm using a 6ft Walco box blade(with scarifiers) on mine without problems !
A 6ft blade will be fine for your tractor ,
Do you push wet heavy snow?
KC
/ Rear Blade #5
I use it to push/pull ,grade dirt , and gravel .......
pushing snow with it would be really easy !!
i'm sure your ck20 would be able to push a 7ft rear blade !
/ Rear Blade #6
KC
I would check with a dealer and purchase a rear scrape blade, (6' or 7') that I could rotate. A blade that is to long will strike the tires and lift arms preventing you from rotating the blade to push snow and other light materials in reverse with. Also look at the weight of the blade. A light blade will bounce and leave a wash board look.
/ Rear Blade
Weight is important, i agree. How heavy is heavy enough?
KC
/ Rear Blade #8
I would REALLY check into that before making that purchase. I mean REALLY check into that. I run a 7ft. blade currently and I wouldn't touch a 7ft. blade with a CK20. To big, to cumbersome, to wide. Can it move it, lift it, etc. Probably, but why use a hacksaw to cut butter . . .
/ Rear Blade #9
I agree with you ,
i didn't meant he should go and buy a 7ft
I use a 6 ft box blade without problem
/ Rear Blade #10
I go with Gator on turning the blade around, I have a 6' KK tilt blade on my ck30hst, it is really handy to raise it up and turn it around.
Mike
2002 CATERPILLAR 247 SKID STEER (A64279)
2002 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 ISUZU NRR 4X2 S/A 6 COMPARMENT  BEVERAGE TRUCK (A59910)
2019 ISUZU NRR 4X2...
2007 FRAC TANK 500BBL WHEELED (A63569)
2007 FRAC TANK...
2015 WESTERN STAR  4900 SB (A63569)
2015 WESTERN STAR...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
