Rear Blade
/ Rear Blade #1
kcook
MI
Cub Lawn Tractor
How big of rear blade for a CK20S Hydro. THis will be used for moving snow and dirt.
KC
/ Rear Blade
I'm using a 6ft Walco box blade(with scarifiers) on mine without problems !
A 6ft blade will be fine for your tractor ,
Do you push wet heavy snow?
KC
/ Rear Blade #5
I use it to push/pull ,grade dirt , and gravel .......
pushing snow with it would be really easy !!
i'm sure your ck20 would be able to push a 7ft rear blade !
/ Rear Blade #6
KC
I would check with a dealer and purchase a rear scrape blade, (6' or 7') that I could rotate. A blade that is to long will strike the tires and lift arms preventing you from rotating the blade to push snow and other light materials in reverse with. Also look at the weight of the blade. A light blade will bounce and leave a wash board look.
/ Rear Blade
Weight is important, i agree. How heavy is heavy enough?
KC
/ Rear Blade #8
I would REALLY check into that before making that purchase. I mean REALLY check into that. I run a 7ft. blade currently and I wouldn't touch a 7ft. blade with a CK20. To big, to cumbersome, to wide. Can it move it, lift it, etc. Probably, but why use a hacksaw to cut butter . . .
/ Rear Blade #9
I agree with you ,
i didn't meant he should go and buy a 7ft
I use a 6 ft box blade without problem
/ Rear Blade #10
I go with Gator on turning the blade around, I have a 6' KK tilt blade on my ck30hst, it is really handy to raise it up and turn it around.
Mike
2018 CHEVROLET EXPRESS 3500 4X2 BOX TRUCK (A59906)
2018 CHEVROLET...
2008 Ford Explorer SUV (A60352)
2008 Ford Explorer...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
Mini excavator set attachment (A61567)
Mini excavator set...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
