Rear Blade Rear Blade Stand
/ Rear Blade Stand #1
jrepp
North West Louisiana
Kubota L5030HSTC
Has anyone built or added a stand to support a rear blade when it is off the tractor. Any photos or drawings would be great.
/ Rear Blade Stand #2
Here is a picture to give you an idea of what can be done. The stand is 1" x 1/4" square tubing. The holder is 1.5" x 3/16" square tubing. The foot pad is a small piece of 2" bar channel. The 1" tubing stand fits inside the 1.5" tubing holder with a little slop to allow the stand enough room to move up or down. There are several holes drilled into the stand to allow the stand to be fixed in several positions up or down.
/ Rear Blade Stand #4
I just put a jackstand under my rear blade. Works fine unless you need to move it frequently.
/ Rear Blade Stand #5
I will take a picture f my rear blade tomorrow. It is a Frontier RB2072 and came with a stand buit on. It is nothing more than a welded piece of tube with a steel leg rod that slips in and then is pinned to hold it in place. Reverse it (leg in the air) when the blade is in use.
/ Rear Blade Stand #6
</font><font color="blue" class="small">( I just put a jackstand under my rear blade. Works fine unless you need to move it frequently. )</font>
That is what I did too but I found that it will stand up on its own by tipping it back slightly on the angleiron behind the blade (on a concrete floor). It seems fairly stable. I would not do it this way if kids were around.
/ Rear Blade Stand #7
</font><font color="blue" class="small">( It is nothing more than a welded piece of tube with a steel leg rod that slips in and then is pinned to hold it in place. Reverse it (leg in the air) when the blade is in use. )</font>
I just saw a picture of a stand (in another thread) that sounds similar. The stand is by Steve_Miller. Nice simple design.
http://www.tractorbynet.com/forumfiles/798929-new%20pics%20004%20%28Small%29.jpg
/ Rear Blade Stand #8
Here's another option that could be used for just about any implement.
/ Rear Blade Stand #9
Thanks Bota - that is exactly like the Frontier stands.
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
UNUSED SDLANCH HYD DUMPER (A64280)
UNUSED SDLANCH HYD...
Redball 6 Row Hooded Sprayer (A64119)
Redball 6 Row...
2716SFL (A61567)
2716SFL (A61567)
2025 Swict 60in. Bucket Skid Steer Attachment (A61572)
2025 Swict 60in...
