Rear Blade Rear blade sizing
/ Rear blade sizing #1
zslnk
Bronze Member
ON, Canada
MF 135
Hi,
I have a Massey 135 that I'd like to get working. I have a long gravel drive that I'd like to freshen up and some grassy area with ruts and high spots that I wish to break up and flatten out. I've purchased a GILL 8' blade at a good price and wonder what size would best suit the 135. The price was right and the option to cut the 8'er down would be available to me. With the 8'er at 45deg I would about match my track width of 6'.
/ Rear blade sizing #2
I think for a 135 you would want a 7' blade.
/ Rear blade sizing #3
That is how I would size it, maybe slightly wider. I'd make sure I cover my tracks while at the max angle I would be using. If I had a landscape rake, I would go wider yet.
/ Rear blade sizing #4
Give it a go the way it is. No harm done. Try it before you cut it. Its easier to cut than to add!
/ Rear blade sizing #5
X2
Give it a try. You will soon find out if it needs cut down.
/ Rear blade sizing
Sounds good, I was looking for a 7' blade but all the ones I found were puny until I saw this CAT1/2 beast. The others looked like if you backed up into anything they would fold. The tractor lift arms are the sacrifical item with this blade. Hmm... There is also a place for a hydraulic angle ram which would be a great option if I installed a valve on the tractor.
/ Rear blade sizing #8
As others said... that size good for ditching.
/ Rear blade sizing #9
1) Measure your rear tires, outside sidewall to outside sidewall.
Multiply by 1.4.
This is how wide you will need the blade to cover your wheels with it set at 45 degrees.
2) Measure your rear tires, outside sidewall to outside sidewall.
Multiply by 1.15.
This is how wide you will need the blade to cover your wheels with it set at 30 degrees.
3) Determine if you need 45 or 30 degree operation.
4) Go blade shopping.
/ Rear blade sizing
That puts me at 7-8' at 30 and 45deg. Looks like the 8'er will be a good start. Thanks for the input.
/ Rear blade sizing
So I ended up looking at a few blades but bought a Gill / Woods HBL-96 made in 1996. It has some wear on one side of the moldboard but I can hardface that back into shape if it bothers me. It was alot of steel for a few hundred bucks. Needs paint.
There is quite a bit of play in the pivot mechanism but nothing looks worn, just a large gap. Is this normal?
/ Rear blade sizing #12
That gap is normal. I have a Woods HBL84-2 and Monroe Tufline GB4-72. Did you get the lift arm pins?
/ Rear blade sizing
I didn't get the pins, I have some that I picked up at TSC that look like they will work. All the other pins are there.
/ Rear blade sizing #14
The nut needs to be tightened up some. It is on the backside of the blade and you have to look up under the rear bracing to see the nut.
/ Rear blade sizing
I used the blade for the first time after the big snow that we received (16") and the Massey will pull the 8' blade straight (no angle) with a huge load of snow down the drive. It's an awesome setup...
I need to figure out how to deal with the snow after I pull it into the road, I'm feathering up the 3pt to drop the snow but I've yet to experiment with angle to drop the snow into the banks. The Gill(Woods) HBL-96 was a good buy at $400. I reversed the cutting edge as the one side was worn but it had never been flipped. Perhaps a hydraulic angle is in the future.
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
Unused Hustler Side Chute (A66734)
Unused Hustler...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2011 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2011 COMPTANK...
x (A68191)
x (A68191)
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
