Rear Blade Rear Blade Shoes, What do they look like?
   / Rear Blade Shoes, What do they look like? #11
Doh! /w3tcompact/icons/crazy.gif
   / Rear Blade Shoes, What do they look like? #12
I thought them square bits were only for dem thar square screws/w3tcompact/icons/smile.gif
2001 B7500 HST 302 Fel R4 Tires, Befco BRB60
Semper Fidelis
   / Rear Blade Shoes, What do they look like? #13
Don't laugh....it can be done.
Years ago a manufacturing process engineer showed me some literature from a company that made the tools it took to...you guessed it.....drill square holes.
   / Rear Blade Shoes, What do they look like? #14
So exactly what is the purpose(s) of these shoes?
   / Rear Blade Shoes, What do they look like? #15
I had the same problem and went to a Fisher plow dealer. They had a heavy duty, big dish shoe and bracket. Welded them on and they work great.
   / Rear Blade Shoes, What do they look like? #16
Tony - They're called "skid shoes" and they are designed to assist the blade in "floating" on the surface so it doesn't dig in as much. They're useful in plowing snow, because the snow is usually a lot softer than the ground underneath, so the shoes keep the blade from tearing up the driveway as much. Also, sometimes they're useful for helping crown a road - you can put the shoe down level, or even a little below, the blade on the end of the blade that's toward the middle of the road, while raising it or leaving it off completely on the shoulder side. And other similar uses, of course...
MarkC
   / Rear Blade Shoes, What do they look like? #17
I made mine like the ones in DFBs picture. I used skid plate for a trailer jack. Welded pipe to my blade, and pined the shoe to a smaller pipe. It work on my gravel drive.
   / Rear Blade Shoes, What do they look like? #18
I noticed that blacktop was mentioned a couple of times. Is it a good idea to use these when plowing blacktop to protect it or is it better to just swing the blade around backwards? Thanks.
   / Rear Blade Shoes, What do they look like? #19
Re: Rear Blade Shoes - square holes
Knew I'd find it somewhere on the web - brings back memories of engineering school.
Drilling Square Holes
Where's patrickg when you need him - he'd enjoy this link!
Patrick
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A55852)
2013 International...
