Rear Blade Rear Blade Shoes, What do they look like?
   / Rear Blade Shoes, What do they look like? #21
TonyC - They work fine for asphalt in good condition, but you really have to be careful using them on asphalt that has any holes in it - it's better not to have them at all then.
MarkC
   / Rear Blade Shoes, What do they look like? #22
Hoss, just got to read your post. I don't have the shoes for my blade so I can't tell ya how well they work or if using them with the blade angled would cause any problems. On hard ground it seems to me that they should skid /w3tcompact/icons/smile.gif across the surface without gouging it up or digging in much. Just riding on top.
Having the leading edge rolled or curved up would certainly be most desirable. My truck blades have the mushroom style skid shoe that Mark Chalkley first described, but even they will dig in and gouge if the ground is soft. Oh well, two smallfurrows left by the skids is better than to peel up the drive with the cutting edge.
Man, I just hate when that happens. /w3tcompact/icons/frown.gif
DFB
   / Rear Blade Shoes, What do they look like? #23
Done plenty of square holes for carriage bolts in farm equip. but never had the money fer dem der fancy dancy drill bits. Use a torch or stick welder to burn the hole then drive in a carriage bolt or punch with a square shank while the hole is still molten. Been doing dem dat way fer now on to twenty years!/w3tcompact/icons/wink.gif
   / Rear Blade Shoes, What do they look like? #24
Plus, you don' hafta know no trigonometry either!! /w3tcompact/icons/wink.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/smile.gif
Sounds very effective to me.
Terry
   / Rear Blade Shoes, What do they look like? #25
I have the upside down mushroom kind that attach by a round shaft that allows it to slide up and down inside a larger diameter shaft which is attached to the blade. The shaft has a hole drilled in it and you can adjust the shoe height with some large washers by either placing them above or below the sleeve. (A picture really IS worth a 1000 words!) Probably clear as mud by I plow a lot of snow on a combination gravel/blacktop/grass and I''m glad I have them. Saves the grass, saves the blacktop, and allows me to NOT push all the gravel onto the grass!
Also works great for laying a uniform layer of loose material down like sand or gravel. Just set the shoes to leave a 1inch gap and drive. Presto - you have a perfect 1 inch layer left behind. (Can't do that with a box blade although you COULD if it had skid shoes or guage wheels)
   / Rear Blade Shoes, What do they look like? #26
Thank you David for your method.../w3tcompact/icons/smile.gif
But, at the factory... a huge press just stamps out those darn square holes nicely... /w3tcompact/icons/blush.gif
   / Rear Blade Shoes, What do they look like? #27
Blacksmithing made easy! Now, if I could just remember which of those holes in an anvil is the prichard hole and which is the hardy hole...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
John Deere 7410 (A53317)
John Deere 7410...
200lb Anvil (A55853)
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
