Rear Blade Rear Blade - Rotate around
   / Rear Blade - Rotate around #12
I am interested in how do you swing the blade on a rear blade, such as a woods rb72 around?
I understand that there is a pin to pull, but do you just swing the blade around and replace the pin? Do you have to lift the 3 point hitch up or unhook the implement from the tractor? Unhooking doesnt seem to be reasonable every time you want to switch from push to pull with the blade.
I have a JD 3720 with the quick hitch and don't know if there is enough distance to swing the blade around. I guess the question is how far back from the tractor is the blade?
Thanks,
Matt
I can swing my RB7 which is a older version of the Woods RB 84 on my Jinma 284 without taking it off. Just pull the pin and swing it.
Sorry but the pic was with my cell.
Chris
   / Rear Blade - Rotate around #13
On my old tractor I backed up to the edge of the road ditch and lowered the blade enough to clear the rear wheels.
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51242)
SAKAI SW502S-1...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
JLG MAN LIFT (A50322)
197711 (A51244)
197711 (A51244)
IH 470 Disk (A50515)
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
