Snow Attachments rear blade or box blade
   / rear blade or box blade #1
brown1
grass lake mi
bobcat ct235
am debating the purchase of a box or just scraper blade. i have a front plow and am looking to use this for counterweight/ getting snow close to buildins or cars in the drives i do. i feel the box blade may have a few more uses for only a couple hundred more. i have tried saving $ on several other purchases and eventually end up getting what i wanted in the first place. any thoughts? another snowstorm is supposed to be here tomorrow night!
   / rear blade or box blade #2
If you can swing it, get both. :thumbsup: They each have their intended purpose and they are not the same, not at all. ;)
   / rear blade or box blade #3
a box blade does not work very well for snow removal. the sides of the box scrap the drive
   / rear blade or box blade #4
Spend your money on a heavy duty blade. You can find used blades on CL from time to time for cheap.
   / rear blade or box blade #5
I have both. You are right that the box blade has many uses, but snow removal is not one of them. For snow removal, you should get a scraper blade that can be angled 20-30 degrees.
   / rear blade or box blade #6
I use a homemade box blade with a 24" high box. Works great for me.
   / rear blade or box blade #8
A back blade won't make much counter weight, but it's good for moving small amounts of snow much quicker than then FEL.
Ralph
   / rear blade or box blade #9
   / rear blade or box blade #10
I have had both in different sizes. For snow removal wider is better within reason. I'd sum it up like this. A box blade is better for cleaning areas that are tighter and lots of hard to get to areas. In your driveway. Blades are better for long driveways. I used to use a back blade for my drive. Three maybe four passes and i was done. Then I got a blower. I never used my blade anymore so I sold my last one. Now I went front mount, I use my box blade for counter weight and those hard to get areas.
A box blade a long drive is pretty frustrating as it loads up I. Forward and makes a mess in reverse. This my experience YMMV.
If you can buy used and buy both try it out for yourself than resell the one you like less. Good luck and have fun.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2006 Nissan Xterra Multipurpose Vehicle (MPV) (A51694)
2006 Nissan Xterra...
Year: 2022 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 6,257 Plate: Body Type: 2 (A51692)
Year: 2022 Make...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
