rear blade modifications
/ rear blade modifications #1
bher
Lancaster, PA
NH TC 29D
I decided to modify my Befco rear blade to make it better for pushing snow. First I added a 1-inch thick rubber soft edge. Then a 2" by 10" cylinder to add power angle. Finally, I made a plate the bolts to the top of the blade. This extends the height of the blade to 18" The heavy snow that we got last weekend gave me a chance to try everything out. Overall, everything worked great. My productivity is up at least 50%. Here are some pics:
another pic
another
one more
last
/ rear blade modifications #6
thanks for the pic's- been thinking about the power angle idea myself- interesting way you did it. I have some salvaged cylinders from the outdrive of a boat. I just need to come up with a valve.
/ rear blade modifications #8
Brant,
Nice job, you just gave me the incentive to modify my blade as well. Not only with the rubber cutting edge, but the power angle as well. Only thing is this will lead to adding some more remotes.
Steve
The cylinder came from Surplus Center. I believe it is Chief brand and nothing fancy.
/ rear blade modifications #10
Great post.
Where did you get the rubber at?
/ rear blade modifications #11
Another thing that works well is end plates. They help keep the snow moving instead of falling off the sides.
Solo
2007 Mack CTP713 Wet Kit T/A Day Cab Truck Tractor (A64194)
2007 Mack CTP713...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2015 LeeBoy 8510C Asphalt Paver (A64553)
2015 LeeBoy 8510C...
2 Row Cultivator (A64047)
2 Row Cultivator...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
