Rear Blade Rear blade hydraulic angle kit
/ Rear blade hydraulic angle kit #22
I have the 8 ft version of that, all hydraulic, angle, tilt, offset, and a hyraulic center wheel ...couldn't be happier and, yes, it does reverse.
I've been back and forth between the RBT3596 and the RB3796.
RBT35: 795 lbs, 30" of offset, hydraulic options in angle, offset, and tilt. $2500 without hyds.
RB37: 665 lbs., 26" of offset, hydraulic option only for angle, BUT you can swap the blade for a rake (pull king pin, remove blade, install rake) on the same housing. My tractor has top-n-tilt, so don't need tilt on the blade. $1550 without hyds or rake.
Thoughts anyone?
/ Rear blade hydraulic angle kit #23
How do you have 6 rear remotes? Or do you mean 3 with two connections each?
FYI: JoelL last posted to TBN in 2014. He may not answer.
Angle, tilt, offset would take 3 SCV valves (6 connections), so if he also has a hydraulic center wheel (?), maybe he really does have 6 SCV's.
/ Rear blade hydraulic angle kit #24
Here is an M7040 with 6 sets of rear remotes.
Sorry about the sideways picture. :ashamed:
/ Rear blade hydraulic angle kit #25
It is a very nice blade, I would love to have the RBT3584 to use with my 3215. But, I will have to wait for awhile. :(
Brian - to rub it in my 3584 has been sweeeeeeet moving snow. Thanks for twisting my arm. :thumbsup:
/ Rear blade hydraulic angle kit #26
Powers, you happy with the 84, or would you have preferred a 96? I will need to run mine at 45 degrees to pull #34 rock back into the road...96" at 45 degrees is only 67.2" wide (multiply by 0.7).
/ Rear blade hydraulic angle kit #27
I have a 6' three point hitch manual angle rear blade with rear hydraulic remotes on my tractor for a backhoe. Is there a kit one could purchase, cylinder, hoses and valve to make my blade hydraulic angle? Or, possibly purchase these items seperately to make the kit myself?
Thanks Drew
I'm not sure how the backhoe hydraulics work on your Kioti so I don't know if you could solve the valve problem by doing something like this. I was able to add two rear remotes to my Kubota L3430 by using the backhoe hydraulic circuit.
I mounted a Prince FEL valve to the ROPS and plumbed it in series with the backhoe hyd. hoses:
I added 2 sets of connectors below the existing set:
I use it to control a T&T kit from Fit Rite as well as the angle cylinder on my rear blade.
