Rear Blade Rear Blade for JD 5303
   / Rear Blade for JD 5303 #81
Love to have a 3584 but I don't need it as bad as I need some other things such as a good core aerator, Harley rake, and a new 2720. You can tell by my pictures that the 1998 rear blade hasn't seen much use. Now if the economy improves then I might get one sooner than later.
This is true, so probably no need to spend money where it just isn't needed.
I understand that all to well. :(
   / Rear Blade for JD 5303 #82
Don't see the need for the large gusset plates since the top link is free to move from side to side,:confused: am I missing your intent?
The intent was to prevent it from bending like it has obviously done before. I too have been trying to figure that one out:confused2:
While the gussets may not be necessary, they are easy and cheap to add, and you see all of the big blades have some sort or triangulation there. And I too have been known to use the blade with a pull and lift method to rip out some smaller stumps. Allthough I would think it would bend up instead of down, either way, gussets will help with that.
   / Rear Blade for JD 5303 #83
Having a blade like this I think the added steel on the bottom to box it in is more than adequate and think that suggestion was well founded. If you are trying to lift and pull a stump out with this blade I would use the center of the blade. Just as using a fel to lift a load from one edge can tweak the loader I think this was the result of abuse. Better to bend these front cross pieces than twist the main beam because they are easier to fix.
Using the blade as it is intended I doubt the OP will have a problem with it. I would recommend he straighten them and box in the bottom as you recommended.
You guys definitely have an eye for catching things out of place and the knowledge on how to correct and improve it. If I can make time today, I plan to put together an all inclusive list of things that need correcting and post it. So far I agree with the vertical and horizontal bracing of the mold board and straightening the 3pt hitch and boxing it in for added strength. I also would like to see what the repair work around the hitch was for and if it can be improved on, primarily for cosmetics. I do not intend to ever try to pull anything up with this tool. If there ever was contact with a stump or root, it would be accidental. I have seen the results of using tools outside of their intent. Doesn't take long to ruin things.
   / Rear Blade for JD 5303 #85
Can of JD green paint:thumbsup:
No harm in popping out stumps, as long as you have a blade strong enough for the tractor, and you do it right in the middle and not out at one end.
   / Rear Blade for JD 5303 #86
Here's what I came up with so far, split a piece of 4x6 x 1/4" rectangular tubing and fitted to the blade. Tell me what you think before I clean them up and weld in place.
Guy's the more I look at this the more I think the back braces need to be more substancial, deeper and taller. Steel for this is pretty cheap, a 6x8 or 8x8 drop of tubing about 4' long is enough to make this repair. I am thinking I will wait until I go by the steel yard and see if I can find a more appropriate piece of steel to use for this. I would make it the same way but bigger, deeper, and better.
   / Rear Blade for JD 5303 #87
I dont really think it is necessary for your tractor or even the op's, but there is no harm in going bigger just to be sure. Keep in mind that the curvature of the blade, and the lip at the top and lip at the bottom also offer significant strength vs just a straight piece for a moldboard. Also, adding a piece vertically out at the edge like you see on some blades (like the new EA blade) also offers strength by forcing the moldboard to remain curved.
   / Rear Blade for JD 5303 #88
Why not a piece of 6" or 8" channel?
With all of the suggestions and input, I think I have a plan:
1) straighten 3PT hitch, replace pins and close in bottom and front, but leaving room to access nut on pin
2) add vertical bracing on each end of moldboard
3) add 6" or 8" channel across back of moldboard
4) replace cutting edge with bolt on type
This seems to be similar to what is on the Frontier RB2184 which is rated for 60 HP 4WD unit. I think I would be ok since the JD 5303 is rated at 64 HP at engine.
May try to get by to see the welder this evening.
Anyone see any other needs I am missing?
   / Rear Blade for JD 5303 #90
There would be nothing wrong with welding the new cutting edge on. I doubt you would ever wear one out. You would probably have to go back to deere to find one that will bolt on.
2018 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2018 Ford F-550...
2012 PROCO KILL TRAILER (A58214)
2012 PROCO KILL...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2000 Mack CH13 (A56435)
2000 Mack CH13...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
