Rear blade dilemma. Options?
   / Rear blade dilemma. Options? #1
Soldier415
Platinum Member
Vermont
2001 Kubota L3010GST. 2005 Kubota L3430HSTC
I currently have a 6' light duty rear blade from Tractor supply. Main use for it would be reshaping/crowning my 1/4 mile drive. I use a LPGS for general refinishing but I have a large section that needs more material spread as it is flat and there is not enough to scrape up.
My rear tires are 70" from outside edge to outside edge. So when the blade is angled the tires are wider than the blade and due to ditches and drop offs I can't put the rear wheels over to get the blade to the edge.
That would be solved by going to a wider blade, the problem being my driveway is 10' wide so the 5' coverage when angled allows for the blade to shape exactly one half at a time. If I went to say a 7' blade, which would be just wider than the rear tires when angled, it would now extend 1' over onto the other side of the drive preventing me from building a crown in the center right?
The only option I can think of would be getting a 6' blade with offset capability which would allow me to get the blade to the edge of the driveway while only covering half the road width. I would also like one with a gauge wheel on the back as there are a number of changes in slope.
Am I correct in my assumptions about the problem associated with going to a wider blade? Would 6' blade with offset be the ideal solution?
Tractor is a L3430HSTC with 3 remotes and top n tilt.
   / Rear blade dilemma. Options? #2
I have a 9" blade. You can clearly see that I was not cutting 9' wide. You have top & tilt, (easy control) I would go with a 7' blade. ;)
   / Rear blade dilemma. Options? #3
No!
Your assumptions are not correct!
You can make a crown with a 7', 8', or 9' blade, you just need to set the proper tilt.
An offset blade would be very desirable for what you want to do!
Forming the crown is all about technique.
You might try to find a video showing how a road/highway/construction grader works.
   / Rear blade dilemma. Options? #4
How about kicking the blade over to one side using the stabilizing/turnbuckle arms on the 3pt lowering links? You ought to be able to get close to a foot.
No!
Thank you for the input. Been looking at rear blades and thought a Woods HBL84-2 would be a good choice: Product Details
   / Rear blade dilemma. Options? #7
Better to produce tilt by moving Lower Link stirrup pin adjustment from default upper pin position, to one of two lower pin positions on the left side, lowering left side of blade, raising right side relatively. Remember: Lower hole = lower implement.
(Small tractors have only two pin holes in the stirrup, some Category Two tractors have four pin holes in the stirrup.)
Usually you obtain a greater degree of manual adjustment making the pin adjustment(s) and the two Lifting Rods share the load more. You can fine tune tilt by screwing the right Lifting Rod adjuster in or out.
Make the pin adjustment before mounting the implement. Clean and grease the pin(s) for easier insertion and removal.
When using a Three Point Hitch mounted Cultivator or Box Blade, and perhaps rear blade oriented perpendicular, sometimes it can be helpful to lower right and left pin adjustments, obtaining more bite from the implement.
And, YES, hydraulic Top Link and right Lifting Rod adjustment from Fit Rite is much superior. With T'nT installed you have hydraulic control on the right Lifting Rod and manual adjustment on the left Lifting Rod plus hydraulic control of Top Link length.
   / Rear blade dilemma. Options? #8
I had a 6' medium duty blade, and upgraded to a Land Pride RB3784 (7') blade. I got it with the side plates, shoes, and hydraulic angle options. Without those added options, it looks like its just a little heavier than the Woods you are looking at, so a good comparison. I was considering a model with the wheel like you are, but decided to skip that. I found the side plates help tremendously for pulling and redistributing the 411 (1" down to fines) crushed stone. I haven't found the shoes to help much so I keep them raised. I like to set my blade angle and height, put the tractor in low range, 1st gear, and crawl s l o w l y up the drive. I usually enjoy a beverage of my choice, relaxing and making small tweaks to the blade as I go. The blade fills to the top, rolling the spoils forward and redistributing. I can see/feel humps as I drive over them (although they are nearly gone since getting this blade) and raise/lower the blade to level those areas. Getting this blade has been the best decision I've made for attachments. I used to dread heavy storms, knowing my drive washed out down the 400' hill section. Now I enjoy getting the time on the tractor, knowing how easy and relaxing it is. We've had 6" of rain in the past 2 weeks, and I'll be regarding the drive this weekend for the 3rd time, and I'm looking forward to it (thanks to the Top n Tilt from Fit Rite Hydraulics, and my new blade).
Another question. Would the 7' blade end up being 6' wide when angled? That would only leave me an inch clearance width on either side of the tires?
   / Rear blade dilemma. Options? #10
Angled how far?
22 1/2* = about 78" wide
30* = about 74" wide
35* = about 66" wide
45* = about 60" wide
Remember that you will have offset. I just don't think that a 4000lb + or - tractor is going to handle an 8' blade very well. Now if you have your tractor ballasted and you are up over 5000lbs, maybe, but still seems a little light to me.
Good luck.
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2012 International 4300 Reefer Truck (A53472)
2012 International...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
