Rear Blade Rear blade+box blade +landscape rake is there any additionla beneift to a landplane?
   / Rear blade+box blade +landscape rake is there any additionla beneift to a landplane? #21
One of the things I did with my rake was to add some plates to the ends to prevent gravel from spilling out and leaving gravel trails (i.e., "box rake")...one of the benefits of the plates is that they (plates) create an "edging" effect along the shoulders...especially when tilted slightly.... a larger sharpened plate would make an even better "edger"...
Do you have ditches along the shoulders? is the grass you are asking about grow between the ditch and the drive?
   / Rear blade+box blade +landscape rake is there any additionla beneift to a landplane? #22
I maintain our driveway with a Box Blade. It took me quite a bit of time before I became somewhat proficient with using it. One of the reasons being that I have a prothesis on my left leg below the knee, and I have to climb on and off the tractor quite a lot. Since I just paid off my tractor several weeks ago, I have begun setting money aside for purchasing a T&T come Spring time. BTW, best wishes and welcome aboard.
   / Rear blade+box blade +landscape rake is there any additionla beneift to a landplane? #23
It is hard to describe in words how much easier your life will be with T&T....I have severe arthritis in both my hips and climbing on and off the machine is the pits...
Not only that you will be able to make minor changes in attachment attitude that you did not bother with prior...and your end result will make you proud...cheers...!
The grass that I have is right up against the driveway, it is level about 2 feet wide, then it dips gradually to a shallow ditch.
Thanks again to all for the replies and tips!
   / Rear blade+box blade +landscape rake is there any additionla beneift to a landplane? #25
No picture available because my clever brother is the one who made this thing and he lives 200 miles from here. But here is a drawing from my memory. I am no artist as you can see. If you turn the rake backwards you get a scraper. If you turn it normal you get a drag. It is for lightish work depending on the size angle you use.
Thanks...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2002 Ford F-350XL Super Duty (A57148)
2002 Ford F-350XL...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
EDGER & FRONT TINE TILLER (A58374)
EDGER & FRONT TINE...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
