Ballast REAR BALLAST WEIGHT?
/ REAR BALLAST WEIGHT? #1
richfromPA
pa
n.h. tc21d
hey all,
i got a bx2200 and im gonna make a rear 3pt counterweight. what would be a good weight? i was thinkin about 200lbs. thanks for any help /w3tcompact/icons/smile.gif
rich
/ REAR BALLAST WEIGHT? #2
Rich; I am currently using a weight bracket with 220lbs on my BX. It seemed to be just right for traction when I was pushing snow, but I would like more weight when doing heavier loader work. I plan on acquiring some more suitcase weights soon.
/ REAR BALLAST WEIGHT? #4
Nice job, Pks. When I commit to buying a tractor I'm gonna make me one of those.
/ REAR BALLAST WEIGHT? #5
andy: thanks for the post .i have a b2400 and will deffinetly use your suggestion. that is a real slick idea. good job.
FRANK
/ REAR BALLAST WEIGHT? #6
Here is a photo of the weight I made for my B8200 and now use on my B2710. It is made from an old water tank for a well and filled with about 500# of lead. Works well and is very small.
/ REAR BALLAST WEIGHT? #7
Hey Von,
Where'd you get the lead? Was it expensive???
/ REAR BALLAST WEIGHT? #8
I've been meaning to ask this, and this looks to be a good thread to ask it, so:
"What's the proper amount of rear ballast to use?"
I have a B2910 with a rear weight box with 700 pounds of lead (free from a co-worker of my wife /w3tcompact/icons/smile.gif). I haven't used the weight box since I just recently took the back blade off, but logically it would seem that the rear ballast should be equal to the weight in the FEL. Is that correct?? If so, that can be a pain in the a** since moving wood chips or rock would mean removing or adding weight (not that big of deal since I have 2 150# lead plates and the rest in small 35# tubes), but still a pain.
Jerry
<font color=orange>SE Minnesota</font color=orange>
/ REAR BALLAST WEIGHT? #9
Jerry,
Do you have access to Microsoft Excel?/w3tcompact/icons/smile.gif
I have an Excel file with some calculations I did to try and figure out "how much ballast is enough" and make sure my tractor was going to be stable. Someone with more experience could probably just eyeball it, but I don't have the experience and was curious about how the numbers work out.
As I see it, it's all about center of gravity - not height, but length-wise, and the resulting weight distribution on each axle under different attachment combinations. You start out with the tractor only, which has a weight and a c.g. location along it's length (this is what determines your front/rear weight distribution, like 60/40, 50/50, etc.). As you consider different attachments, like a loader, you add the approximate weight of the attachment and it's approximate c.g. Depending on the attachment's c.g. and weight, then the c.g. of the tractor plus attachment will shift. If the c.g. is shifted too far towards either the front or rear axle, that's when you start to lose stability.
What I found out was that running a 400 lb tiller as counterweight for the loader is pretty safe, unless I was really maxing out the loader capacity (breakout force). I have seen this in practice while carrying some good size rocks in my loader - the rear wheels did not lift, but the front tires left some impressions in the lawn where there would usually be none, meaning that the front end was pretty loaded up.
Well, I guess I'm done. Nothing like whipping something simple into a complex mess/w3tcompact/icons/wink.gif.
/ REAR BALLAST WEIGHT? #10
I used the old lead type from a print shop. I only wanted the cabnets that it came in. So I scraped out the lead and took what I wanted and sold the rest.
/ REAR BALLAST WEIGHT? #12
RichinPA,
I use the LP 4' box for my ballast. Not to imply buying one just for weight, but it weighs 303 lbs (as per Landpride web info) and there is absolutely no strain, etc.. with that amount of weight. I have just cleared and graded (lots of digging with the FEL too) a spot for a storage building and the counterweight seemed perfect for the FEL. Hope this helps regarding your post.
David
/ REAR BALLAST WEIGHT? #13
No problem, John. It is already on the way.
- Rob
/ REAR BALLAST WEIGHT? #14
Rich,
I've got a Bx2200 and use a NH 3pt wt bracket that can hold 5 - 50lb weights. Very compact - doesn't stick out far at all. I was using 4 (200lbs) throughout the winter to move snow which worked fine. This spring I used the front loader to move a full bucket of very wet dirt/mud and the rear end seemed to bounce quite a bit. I'm now using two additional weights for a total of 300, which seems more stable. The manual recommends rear implements for ballast in the 300+ range.
Frank
/ REAR BALLAST WEIGHT? #15
Von, what I see is 'very little weight', and a whole lot of tractor that a new owner is very proud of!!! Nice rig Von, hope you are still enjoying the dickens out of it! /w3tcompact/icons/smile.gif
/ REAR BALLAST WEIGHT? #16
Frank,
That NH 3pt. hitch wieght bracket is exactly what I want. Got a NH part number for that?
-- Rock
/ REAR BALLAST WEIGHT? #17
Rock,
Sorry it took so long to respond - I hadn't logged on for a while. My dealer purchased the bracket from North State Sales. I don't know if this part number is NH or North State, but here it is.
The bracket is part number 7001 - I paid $94. The part number for the weights is 3113 - I paid $39 each for those. The bracket has this information on a label glued on: North State Sales, 2204 N. Church Street, Greensboro, NC, (336) 275-9578.
Frank
/ REAR BALLAST WEIGHT? #18
Nice idea, well realized. I will build one of these, I think, instead of a baffled drum of water I was considering. Shouldn't be too hard to imbed some bolts to allow adding additional weight(s) when desired.
Patrick
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2022 YANMAR VIO35-6A EXCAVATOR (A59823)
2022 YANMAR...
John Deere 7810 (A60462)
John Deere 7810...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2018 FREIGHTLINER...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
