rear balde for 50hp tractor
   / rear balde for 50hp tractor #1
Atobuk2001
Battle Creek, MI
Kubota L4740 HST 4wd
What would be the correct weight for a 7 foot blade, on a 50hp tractor, for snow removal. My dealer wants me to buy one that weighs 320lbs. I don't think this is enough since my B7500(21hp) I traded in rear blade had to weight atleast 200lbs. This tractor has over twice the 3pt lifting capacity as the B7500.
   / rear balde for 50hp tractor #2
Atobuk, Not sure there is a correct size, it all depends on what your going to do with the implement. I can tell you that the 7' Rhino that I use weigh's about 400# and works well with a 60hp tractor. More it weighs, the deeper it can cut when needed. JMHO :)
   / rear balde for 50hp tractor #3
That seems pretty light to me. I run a Landpride RB3584 rear blade. It's 7ft. (84") and it weights in at 533lbs. It's pretty heavy duty, probably the heaviest model they make without going to the hydraulically swing/tilt models. I am running it on a 45hp tractor.
http://www.landpride.com/ari/attach/lp/public/specs/301-131s.pdf
   / rear balde for 50hp tractor #4
If it were me , I would run the same LP blade that mark. r is running. You might get by with a LP RB2584 though, it is rated for 25-60hp and weighs 396lbs. That might be ok for snow, but I would not use it for dirt, but that is just me.
Good luck
   / rear balde for 50hp tractor #5
Good luck
That's a good point. I've used it for both snow clearing on asphalt as well as moving lots of dirt. I used it along with my loader w/tooth bar to build my driveway extension.
   / rear balde for 50hp tractor #6
Mark, does your tractor lift your rear blade high enough for you? It seems to me that the hitch point on most of the rear blades need to be redesigned. I know that I am going to rework mine.
   / rear balde for 50hp tractor #7
For the most yes. In other words if I'm using it raises it sufficiently in terms of height. If I know I am not going to use it for awhile and it is on the tractor than I will shorten the top link to increase height? Does that make sense?
   / rear balde for 50hp tractor #8
Hmmmm, it looks like 10 pounds per tractor hp would be a good rule of thumb. 200# for your 21 hp B7500. Your 50 hp tractor should then have one around 500#. Makes sense to me as a "minimum" rule. More weight will make the implement more productive and less prone to breakage.
jb
   / rear balde for 50hp tractor #9
That is the same thing that I do, but I still want a little more height. I feel that the boom should be parallel to the ground when working.
Just my opinion
   / rear balde for 50hp tractor #10
jb
That sounds like it is a good rule to start with. I know that I twisted up my first rear blade, and it was 680lbs I think. My new one is 1130lbs and rated for a 15,000lb machine. I don't think that I will have any problems with the new one.:D
Ficklin 4500 Gravity Wagon (A50774)
Ficklin 4500...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
JMR 72" Root Grapple (A50121)
JMR 72" Root...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
