Rear axle seals replacement
/ Rear axle seals replacement #1
Topwood
Dong Feng DF354
Hey people
I have a 18 year old Chinese tractor Dong Feng DF354 that needs the axle seals replacing. The trumpet housing will not pop out so now trying to remove the PTO, which also WILL NOT COME OUT... Tips or advice please.
/ Rear axle seals replacement #2
Can you get a parts diagram? Helped me a lot when I did my TYM T254's rear seals. Also, mine had 6 bolts and couple of pins to line the housing up. Took off the wheel and housing bolts, lightly tapped the flange for the wheel working around it and was eventually able to gently/firmly wiggle it off. Mine is small and made of aluminum so it wasn't a big thing to keep it off the ground. I'm assuming yours is much larger. Used RTV to seal the housing when I put it back together.
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2014 Chevrolet Silverado 1500 4x4 Pickup Truck (A59230)
2014 Chevrolet...
2019 CATERPILLAR 326FL EXCAVATOR (A62129)
2019 CATERPILLAR...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
