Rear axle seals replacement
/ Rear axle seals replacement #1
Topwood
Dong Feng DF354
Hey people
I have a 18 year old Chinese tractor Dong Feng DF354 that needs the axle seals replacing. The trumpet housing will not pop out so now trying to remove the PTO, which also WILL NOT COME OUT... Tips or advice please.
/ Rear axle seals replacement #2
Can you get a parts diagram? Helped me a lot when I did my TYM T254's rear seals. Also, mine had 6 bolts and couple of pins to line the housing up. Took off the wheel and housing bolts, lightly tapped the flange for the wheel working around it and was eventually able to gently/firmly wiggle it off. Mine is small and made of aluminum so it wasn't a big thing to keep it off the ground. I'm assuming yours is much larger. Used RTV to seal the housing when I put it back together.
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2011 Chevrolet Express 2500 Cargo Van (A64556)
2011 Chevrolet...
6ft Metal Star (A65583)
6ft Metal Star...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
Columbia Vise (A65640)
