Rear Axle Seal Stuck -- Mahindra but maybe similar to others??
   / Rear Axle Seal Stuck -- Mahindra but maybe similar to others?? #1
chevymanar
Sheridan, AR
2016 Mahindra 2538HST
Hey folks I took on the task of replacing a couple of leaky seals (PTO and rear axle shaft) on my 2016 Mahindra 2538HST.
PTO seal was pretty easy, used a couple of screws to get leverage on it.
The axle seal is proving to be a huge ordeal though. You can't get to it straight on to try and do the screw trick with it, but you can pry on it from the edges. I started doing that, but realized after awhile I was only moving the outer rubber but the inner part that makes contact with the axle shaft just seems to be stuck. I have never dealt with a seal like this before and I am honestly just not sure what to do now. If I could actually access the part that is stuck I could cut it off, but unfortunately I can't get to it (with any tools that I have anyway). I tried to use an air hammer on this inner part like you would a stuck inner bearing race, but since it is rubber that is stuck to the axle shaft it just flexes and won't actually move.
I am attaching a few pictures of the mess I have made along with a picture of a new seal. Can someone help me here?
An idea that I just had and figured I would run it by you guys.... if I can get a pair of snap ring plyers up in there and remove the snap ring I believe the axle shaft should pull out of the housing. That would give me good access to it. I can see the snap ring (pic attached).
   / Rear Axle Seal Stuck -- Mahindra but maybe similar to others?? #3
I’m taking it that you don’t have a service manual, highly believe the snapping isn’t what’s holding the axle in a tractor this size, maybe the outer bearing in place. Almost any tractor axle seal replacement required the removal of the final drive housing to access a nut on the end of the axle-shaft that keeps the reduction gear and all other pieces where they belong. I may be wrong, but urge you to stop and find out for sure before you proceed
You are correct, I don't have the service manual. I do have that exploded view, that is how I got the correct part number I needed.
I will go by the dealer tomorrow and chat with them before I go any further. I need to get my hands on a service manual for future projects, I should have done that before now.
Thank you for the response.
I verified that the snap ring did in fact hold the axle in. I popped it out and the assembly came out. I was able to remove the clip, spring, and bearing and slide the old seal off. I put it back together but now I have ran into another totally different issue.
The bearing touches the housing at the same time as the splines engage. I am trying to engage splines blindly here. So when I insert the shaft and it bottoms out on the bearing I assume it needs to be slightly tapped into place... but I don't know if I my splines are lined up. I gave up for the day but I am hoping there maybe some other section I can remove and have the ability to see the splines. I don't really know what else to do here. I do not want to risk damaging the splines.
I did order a service manual today. I have a feeling it tells me to mark the axle and the housing before I removed it. 😫
   / Rear Axle Seal Stuck -- Mahindra but maybe similar to others?? #6
Sorry for reviving an old thread, but I am going to be helping a family friend replace the same rear axle seal as shown here on a 2538HST. A snap ring behind a captured seal doesn't make sense to retain an axle shaft. How did this end up? I haven't put my eyes on his tractor yet, but he said the oil is leaking inside the rear tire so I assume its this seal. @chevymanar Anymore pictures you have of this process would be exceptional!
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
19200 (A50324)
19200 (A50324)
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
