Rear Axle Failure, Max 28, Service Manual Pages?
   / Rear Axle Failure, Max 28, Service Manual Pages? #1
mike69440
Elite Member
Central NH (God's Country)
2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
Is anyone able to post .pdfs of the service manual pages related to removal and service of the real axle assembly?
Parts list, exploded views etc.?
I drove through into a hole, nothing huge, something hung up a bit,, and right after axle is loose and leaking oil. I hear something broke internally.
I really would like to do repair myself, as tractor service is incredibly expensive, and I do not trust the quality and and skill of the service.
Much appreciated.
Thanks
Worse!!
I'd consider buying an insurance claim, (fire etc.) on a Max 28 or 28 for the parts.
   / Rear Axle Failure, Max 28, Service Manual Pages? #5
Worse!!
Ouch, that looks like an expensive piece of casting.
Hopefully you can get one this year?
I would sell the tractor soon after.
Too many mods and accessories to sell.
A bit more Iron thickness around the bearing housing would have prevented this.
If I owned an aerospace NC machine shop, I could sleeve it with a very complicated sleeve I could design using SW so it would be stronger than a new Housing.
The programing and set-up would be a killer. $$$$
The Axle lock dog is just cast iron crap. Should be hardened steel. No wonder, it was so piss poor to engage. May repair it by welding up some hard facing build up and hand grind.
I'll replace the bearing that go a bit of metal in it.
Damn, this is going to be a project.
   / Rear Axle Failure, Max 28, Service Manual Pages? #9
Wow, that is unfortunate. I tell you, after seeing all the problems my neighbor has had with his Max 28, I would never recommend that model series to anyone. Since they are Mitsubishi made I had expected them to be good, but they are just not well made compared to other models and brands. Wiring and hydraulics have been the typical failure points for people, so seeing this is a new one for me.
   / Rear Axle Failure, Max 28, Service Manual Pages? #10
By the way, any theories as to how the load transferred to that spot to break there? Seems like the outer case didn't really provide any support to the axle at all? Was it a side load that maybe put a "thrust" on the inner bearing?
2014 Electric Cart (A53424)
2014 Electric Cart...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
