Rear attachments, no loader?
/ Rear attachments, no loader? #1
gregp
Newbe question here, but, can i run a tiller or power rake without a front loader attached? I know i need the weight to counter balance the loader bucket but i am not sure about the other way around. I thought i would ask before i became a test dummy. Thanks, Gregp
/ Rear attachments, no loader? #2
No you dont need a loader unless you plan on using a back-hoe
/ Rear attachments, no loader? #3
Or a pretty big brush hog. Ask me how I know that! /forums/images/graemlins/smile.gif
/ Rear attachments, no loader? #4
</font><font color="blue" class="small">( Newbe question here, but, can i run a tiller or power rake without a front loader attached? I know i need the weight to counter balance the loader bucket but i am not sure about the other way around. I thought i would ask before i became a test dummy. Thanks, Gregp )</font>
Most all tractors have weight racks for the front that facilitate mounting "suitcase weights" . I spent the day yesterday on a tractor without a front loader, and a 1400lb bush hog on the back end. I have 660 lbs of iron hanging on the front. Wheels stay glued to the ground.....
/ Rear attachments, no loader? #5
You will know if you need to add weight to the front end, and finding out won't be anything tragic. Just be aware that when you lift the 3pt and the front end gets light, you need to add weights. In the interim, don't lift the 3pt, but steer with the brakes (that is possible on most tractors but not all).
Normally the light front end shows when going up a slope and lifting the attachment at the same time. Be cautious and you will remain safe (not in the category of 'test dummy', IMO).
/forums/images/graemlins/wink.gif
/ Rear attachments, no loader? #6
After he finds out the front end is light.. then he'll learn about 'suitcase' weights. After he goes and prices them, hel'' then learn how to make his own weighted bumper! /forums/images/graemlins/smile.gif
Soundguy
/ Rear attachments, no loader? #7
Soundguy is exactly right. Look around at a thrift store, flea market, etc. for some old barbell weights really cheap and modify them for your own front bumper weights.
Thanks for the replies. I will probably leave the loader on to pick up debry when i use my power rake. But, i will take it off when i use the tiller, easier to get around i think. Thank you all for the information.
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
JOHN DEERE 4230 TRACTOR (A64277)
JOHN DEERE 4230...
2015 GMC Sierra 3500 HD 4x4 Crew Cab Flatbed Truck (A64556)
2015 GMC Sierra...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
Richie 300 Cattle Water Tank (A65640)
Richie 300 Cattle...
90in. Work Bench (A65640)
90in. Work Bench...
