Really would like to mow some grass:
   / Really would like to mow some grass: #11
I have a JD LX 178,
Here's the problem, starts right up,
mows for 10 to 60+ minutes & then shuts off like it is out of gas, but it isn't
Hope someone can suggest an answer.
I had nearly an identical experience with my JD x394.
When it would start to stall I could hit the choke and it would usually keep running long enough to get back to the garage. I would have to work the choke on/off as I went.
Did a ton of research on web. Checked fuel filter and other possibilities. Wound up buying a new fuel solenoid even though mine appeared to be okay ($13.99 at Amazon).
Disconnected the fuel line from carburetor while it was running. Barely a trickle coming out so replaced the fuel pump ($9.00 - $13.00 at Amazon). Still acted the same way.
Finally I disconnected the fuel line at the filter and blew gently back into the tank. It has ran fine ever since. I suspect something in the tank was partially blocking the outlet. Blowing back in dislodged it SO far (~60 hours of mowing) the problem has not recurred.
That is why I put "blow back into fuel tank" as number one on my list in earlier reply.
   / Really would like to mow some grass: #12
I got some bad gas that messed with the valves on my Dixon ZTR that has a Kawasaki engine. Cleaned the fuel system and used some Marvel Mystery oil. It runs fine now.
   / Really would like to mow some grass: #13
If you have non-ethanol available use it. I've yet to have issues with mowers since using non-ethanol.
   / Really would like to mow some grass: #14
I had bees blocking my fuel inlet from the tank to the line. Sucked them out and refilled with the filter funnel and all was good afterwards.
(2) TIRES & WHEELS (A52708)
(2) TIRES & WHEELS...
John Deere 7410 (A53317)
John Deere 7410...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2009 Toro Workman HD Utility Cart (A56857)
2009 Toro Workman...
LOT OF PIGEON HOLE CABINETS (A52708)
LOT OF PIGEON HOLE...
WACKER NEUSON LIGHT TOWER (A58216)
WACKER NEUSON...
