Reaf blade mods, anyone?
/ Reaf blade mods, anyone? #1
Charliebrn
Platinum Member
NW Ohio
Kubota BX-2360
I wonder if anyone has modified a rear blade to change the angle on the rear blade without leaving the seat. I like the rear blade, but it's a pain to get off the tractor, change the angle and get going again. It would save a lot of time, and after all, I'm lazy when I can get away with it.... /w3tcompact/icons/smile.gif
/ Reaf blade mods, anyone? #2
I have an older Deere blade that I can change the angle from the seat. It has a long lever that disengages a stop, which allows the blade to turn (this requires some planning so the pressure is on the blade at the correct place to turn it). Letting go of the lever engages the stop.
/ Reaf blade mods, anyone? #3
A couple of hyd cyls if you have the ports. I'm in the same boat as you, but a little exercise and fresh air is what I need.
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A69167)
2001 FREIGHTLINER...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
2012 DRAGON 130BBL VAC TRAILER (A67714)
2012 DRAGON 130BBL...
