Ready for Winter
   / Ready for Winter #11
Killer_B said:
The 3rd Function SCV does the angling of the blade. The joystick runs the loader as normal. I will probably switch the angle control to the curl function and the curl/dump function to the 3rd SCV.
KB
Sounds like you need a Diverter on that FEL!
   / Ready for Winter #12
Looks like an awesome setup!
It looks like you have level paved surfaces to deal with - did you get away without chains in the past?
   / Ready for Winter #13
Killer_B said:
My parking pad is 60' wide. My driveway is 300' long. Even so, if it were just my drive, I would probably get by with the loader bucket and maybe a rear blower. But, I also have a side job doing three of my neighbors who have longer drives and larger parking areas than I do.
Yeah, I looked at the pic again...I thought where it curves to the left was the end to the side road.
Well, you've got the rig to handle almost any snow that comes your way!
   / Ready for Winter #14
Killer_B said:
They dropped off my slightly used Buhler 60" rear blower today. It seems to be a good fit for my 3320. I am hoping that the front angle blade will handle most of the snow falls we get here in southern Michigan. The blower should handle the rest.
KB
I'm not sure what kind of snowfalls you get there but now that you have the blower why not make it your primary use tool, I don't own a tractor mounted blower only walk behinds but with your concrete drive and manicured lawn I think you would get a better job with the blower. With the blower it's one pass and your done, no going back over and over again picking up the spilled snow, and it moves the snow away from the edges with less chance for damaging the lawn with a plow.
Like I said I don't know how much snow you get, if you get less than 6 inches at a time then the blower might be overkill as it looks like it could handle 16 inches with no problem!
Here's a picture of what the limits are for a loader and plow when the piles at the edges start building up and there's no where to put more snow, you wouldn't have that problem with a big blower.
   / Ready for Winter #15
JB,
That looks like a FVE label on the hood! :)
   / Ready for Winter #16
Ya, good eyes, I never noticed that before, I'm in Newington, I bought mine from Jack, but I know Steve and Dave from the construction expos. I was there Thursday, I'm looking for a hard canopy, a 16' equipment trailer, a pto generator etc etc etc dreaming, but I will get the top this year to help with the sleet and freezing rain.
   / Ready for Winter
I have not needed chains since I moved up from my old Ariens lawn tractor. 4WD seems to provide all the traction that is needed.
   / Ready for Winter
JB4310 said:
.. now that you have the blower why not make it your primary use tool ..
It's a question of speed. With the plow, you fly along in mid or high range. And three passes down a 12' drive way leaves it squeaky clean. With the blower, you creep along in low range. The only time I go to the blower is when there is too much for the plow to handle. That would be about 6" or so. At least that's the way it worked with my last two Kubotas. I'll have to see how it goes with the green monster.
The snow bank problem was not much of an issue the past few years. It seems like a couple weeks of hard snow is often followed by a melt off lately. If the weather was like I remember in northern Michigan in the 70's, it would be all blower all the time for sure.
KB
   / Ready for Winter #19
JB,
I'm from Southington. I've purchased three tractors from Trudeau's/FVE. Jack (and all of the sales staff) are great guys!)
   / Ready for Winter #20
KB
Do you really have to blow in low range? I've never used a rear blower, but with my front blower I go in high range full speed ahead. :)
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
1984 Trailmobile Enclosed Van Trailer (A55302)
1984 Trailmobile...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55302)
2021 John Deere...
2019 KUBOTA SVL75-2 SKID STEER (A52706)
2019 KUBOTA...
