Reading a Surveyors Plot Plan Question
/ Reading a Surveyors Plot Plan Question #21
In many areas, Google maps shows property lines. Switch back and forth between map and satellite view to see where the lines are, if they don't show in satellite view. My corners on Google are within a foot or two of accurate.
This may give you a good idea of where to look for corner pins.
Bruce
In many counties here, the county website has an online tax map (GIS property finder) that you can adjust background map to show Google earth satellite photo with property lines superimposed.
/ Reading a Surveyors Plot Plan Question #22
Just me kind of doing a rough scale on my screen but I would venture a guess the 326 should be 236. Massachusetts is what is known as a metes and bounds state. The distance might be in your deed but might not also.
I run what is called closure on a plat. You start and put in the bearings and distances in around the entire property and should mathematically come back to your starting point. In the case of yours you can not do this because of the radius. I list on my plats a chord distance and bearing for the radius which assumes a straight line from end to end of the curve.
BTW they are bearings on the plat not azimuths. Technical note for anybody who cares.
/ Reading a Surveyors Plot Plan Question #23
Another note. A surveyors joke is GIS stands for Get It Surveyed. Some GIS systems are surprisingly accurate in places while others leave a lot to be desired. I helped draw up our counties 20 some years ago and it is just a pretty pic.
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2011 GORILLA BUILT MANIFOLD TRAILER (A67714)
2011 GORILLA BUILT...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2014 DIAMOND C 45HDT CAR HAULER (A67714)
2014 DIAMOND C...
GENERAC MOBILE PRODUCTS  MAGNUM LIGHT/WATER PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
