reading a dial caliper
   / reading a dial caliper #81
The calipers that offer a display in fractions have always made me scratch my head. I have nothing against fractions, but I have a hard time quickly visualizing if 23/64th is larger or smaller than 3/8th of an inch.
You might know this you might not. To convert a fraction to a decimal you divide the numerator (top number) by the denominator ( bottom number)
Ex - 3/4 3 divided by 4 = .75
Also to find half of a fraction you double the denominator
Ex half of 3/4 is 3/8
half of 3/8 is 3/16
half of 3/16 is 3/32
I figured this out when I was working construction
   / reading a dial caliper #83
Does your thermometer have decimal points?
Well, my digital does and I can see if it's between numbers.
F is a scale that only makes sense if you are force-fed it from childhood.
A 0 point of that has no real connection with any form of logic.
   / reading a dial caliper #84
Proof. ;)
   / reading a dial caliper #85
I will Try to Educate You. Fahrenheit divides Freezing at Sea Level to Boiling into 180 increments. Celsius only 100 increments.
Note the finer divisions? End of discussion.
   / reading a dial caliper #86
Dial caliper reads 1.866" or 47.39 mm.
Yes, agree. 47.39 is technically correct.
although with the caveat that without looking straight down at the dial it is hard to know if the needle is pointing directly at 1.866 or a little past that. Still, it is a +- .001" dial caliper, so you have to estimate that last digit from the closest whole integer.
Being an optimist... and fond of simple numbers....I'd call it 47.40 mm even though I cannot really defend that. :)
rScotty, YMMV
   / reading a dial caliper #87
Yes, the discussion is ended, the world has made its choice. ;)
   / reading a dial caliper #88
Yes, boiling water and frozen water are 180 degrees apart. So in Fahrenheit one can heat beyond boiling to complete the circle back to frozen again. Clearly frozen at 32°F, boiling at 212°F, and frozen again at 392°F. This is why we cook frozen Christmas turkey at 400°F, because that is the 2nd freeze temperature!
Science is fun and so logical!
   / reading a dial caliper #89
Well
Warner von Braun converted to the United States $1 BILL (and above) pretty easily I'm told.
IRONICALLY, it's a very "metric-like" set of numbers and WAAAAY easier to break down than the Deutchmark, Franc or Pound.
Don't even get me started about Rials, Rubles or Yen;>)
   / reading a dial caliper #90
Hmmm. My dial caliper doesn't read in either celsius of fahrenheit.:unsure:
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
2015 DODGE RAM...
2019 Genie GS-3232 32ft Electric Scissor Lift (A55787)
2019 Genie GS-3232...
2016 FORD Transit CARGO (A55788)
2016 FORD Transit...
(INOP) 2022 JLG R3246 ELECTRIC SCISSOR LIFT (A54756)
(INOP) 2022 JLG...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
