Re-Usable Hydraulic Hose Fitting Tutorial
   / Re-Usable Hydraulic Hose Fitting Tutorial #31
Am I the only one who will ask what all the hoses you are making are for????
Call me nosey ! ;)
Call me nosey ! ;)
You are the first:D
2 Projects:
1) HTL (hydraulic top link)
2) New 3rd function valve to replace my diverter valve that runs my grapple.
   / Re-Usable Hydraulic Hose Fitting Tutorial #33
The nut-nipple of the fitting (female end) should not be snugged tight but just loose enough to allow the nut to be turned for installation and correct alignment of the hose without binding.
Jim
This doesn't make sense unless I'm missing something. A crimped fitting doesn't allow for this, why should a reusable?
Andy
   / Re-Usable Hydraulic Hose Fitting Tutorial #34
A very informative tutorial. One question... Why should the stem not be snugged to the collar?
Larry,
We are using instructions from one of our fitting manufacturers that recommend a gap 1/32" to 1/16" of an inch between the collar and the stem.
The reason for this gap is to avoid overtightening which may put additional stress on the stem. Some people, if told to tighten a bolt until it's snug, will continue to tighten it "just to make sure" it's snug. If this happens, you may stretch the stem, putting stress on the fitting that is not only unnecessary, but could possibly compromise the integrity of the stem. Theoretically, overtightening it dramatically could create enough stress that might at some date lead to the stem snapping off in the hose.
The gap eliminates this possibilty, so the gap is a good thing.
Ken Hutchinson
Discount Hydraulic Hose.com
   / Re-Usable Hydraulic Hose Fitting Tutorial #35
Larry,The reason for this gap is to avoid overtightening which may put additional stress on the stem. Some people, if told to tighten a bolt until it's snug, will continue to tighten it "just to make sure" it's snug. If this happens, you may stretch the stem, putting stress on the fitting that is not only unnecessary, but could possibly compromise the integrity of the stem. Theoretically, overtightening it dramatically could create enough stress that might at some date lead to the stem snapping off in the hose.
Ken Hutchinson
Thanks Ken... Sad... I was afraid that might be it so I used snug rather than :eek:tighten. Degrade the assembly by leaving a gap to protect against overtightening by the clueless. It is difficult to explain how to know when to stop, so stop before they even touch. I will go ahead and snug mine to unify the assembly as it should be.
larry
   / Re-Usable Hydraulic Hose Fitting Tutorial #36
larry
Companies have to try to make things stupid proof these days.:confused: Look at the guy who sued a motorhome company and won because he put it on cruise control and went back to make a cup of coffee.:eek: Need I say more?:D:D:D:D:D CYOA!
   / Re-Usable Hydraulic Hose Fitting Tutorial #37
I checked the Weatherhead instructions and they say to assemble them until the 2 halves touch. I guess either way would be acceptable as long as you don't overtighten as Ken says.
   / Re-Usable Hydraulic Hose Fitting Tutorial #38
Not trying to be a smart guy here, just want it to be right when some noobie searches. Once the fitting has been removed, the hose should have the end cut off before a fitting is installed again.
I completely re-plumbed my Case 310 dozer with these fittings. Trust me, the larger fittings are not cheap. :eek:
Hey Brian Very nice work of the restore. What did you use to degrease all the metal before painting? Did you use a Case factory color, and if so, where did you get the paint?
   / Re-Usable Hydraulic Hose Fitting Tutorial #39
What does this have to do with this thread?
It just ruins the whole thread.:rolleyes:
   / Re-Usable Hydraulic Hose Fitting Tutorial #40
Just to be fair, that story is a myth. No evidence has been found to back up this story, or any of the others that were circulated in an email a few years as winners of "Stella Awards" (named after Stella Liebeck, the woman who sued McDonalds because their coffee was too hot).
Stella's story is true, and she won her lawsuit. The other stories were all found to be fiction.
As far as making things "stupid proof," it's kind of a necessity if you're in business.
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
MAGNUM PRODUCTS LIGHT TOWER (A50854)
MAGNUM PRODUCTS...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2023 Ram 4x4 Pickup Truck Bed (A49461)
2023 Ram 4x4...
