Re: R4 Grooving
/ Re: R4 Grooving #1
MacTractor
New Brunswick
2008 JD 2320
Re: R4 Grooving
I just wanted to post pictures of the recent grooving of my R4 tires. I can confirm that it does make a noticeable difference in the snow... Not a replacement for chains or maybe even R3's, but there is a difference.
I ended up doing the front the same as the rear as I figure that any biting edge will help with the R4's due to the stiffness of the rubber compound.
We are also under a major ice storm right now so I am also hoping they will be better here as well. I know chains are the best here but for me I was looking for an improvement, mostly in snow.
/ Re: R4 Grooving #2
Re: R4 Grooving
What did you use to make the cuts?
/ Re: R4 Grooving #4
Re: R4 Grooving
The electric tire groovers drove me nuts with the smell of burning rubber. I took an old panel cutter from my air chisel and sharpened the spur. It will cut a groove only as wide and deep as the spur, but it will do it with almost no effort or smell.
/ Re: R4 Grooving #5
Re: R4 Grooving
Hmmm. I've grooved dozens of Jeep/Buggy tires with a groover like k0ua posted and never noticed burning rubber smell. You gotta stop and sip a Beer every so often to let it heat up again, but then it just gets hard to push.
/ Re: R4 Grooving #6
Re: R4 Grooving
I wish I could have stopped to "Sip a beer" but the boss would take a dim view of it. :muttering:
/ Re: R4 Grooving #7
Re: R4 Grooving
No sense of humor at ALL.... :rolleyes:
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2022 EZ-GO ELITE...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
(3) 11/29-15 Hoosier Dirt Track Tires (1) 29/11-15 American Racer Dirt Track Tire (A64127)
(3) 11/29-15...
275 Gal Chemical Container (A64127)
275 Gal Chemical...
