Re: R4 Grooving
/ Re: R4 Grooving #1
MacTractor
New Brunswick
2008 JD 2320
Re: R4 Grooving
I just wanted to post pictures of the recent grooving of my R4 tires. I can confirm that it does make a noticeable difference in the snow... Not a replacement for chains or maybe even R3's, but there is a difference.
I ended up doing the front the same as the rear as I figure that any biting edge will help with the R4's due to the stiffness of the rubber compound.
We are also under a major ice storm right now so I am also hoping they will be better here as well. I know chains are the best here but for me I was looking for an improvement, mostly in snow.
/ Re: R4 Grooving #2
Re: R4 Grooving
What did you use to make the cuts?
/ Re: R4 Grooving #4
Re: R4 Grooving
The electric tire groovers drove me nuts with the smell of burning rubber. I took an old panel cutter from my air chisel and sharpened the spur. It will cut a groove only as wide and deep as the spur, but it will do it with almost no effort or smell.
/ Re: R4 Grooving #5
Re: R4 Grooving
Hmmm. I've grooved dozens of Jeep/Buggy tires with a groover like k0ua posted and never noticed burning rubber smell. You gotta stop and sip a Beer every so often to let it heat up again, but then it just gets hard to push.
/ Re: R4 Grooving #6
Re: R4 Grooving
I wish I could have stopped to "Sip a beer" but the boss would take a dim view of it. :muttering:
/ Re: R4 Grooving #7
Re: R4 Grooving
No sense of humor at ALL.... :rolleyes:
Peterbilt 377 Semi-Truck (A63118)
Peterbilt 377...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2014 Wacker Neuson ST45 Compact Track Loader Skid Steer (A61567)
2014 Wacker Neuson...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
3ft. 5-Point Metal Star (A61569)
3ft. 5-Point Metal...
JOHN DEERE 4640 TRACTOR (A62130)
JOHN DEERE 4640...
