Mowing RCR 1860 help
/ RCR 1860 help #1
lastborn
Clemson sc
Kubota B3200
Could some of you good people please tell what size socket I need to remove the blades ** and the blade carrier on a Land Pride RCR 1860 bush hog please.
Also, is it regular thread { turn clockwise to tighten } ?
thanks
/ RCR 1860 help
Ok, I got the nut off of the blade carrier and the two blades and blade bolts that go thru the stump jumper--- how does the stump jumper and the blade carrier come off :confused:please?
thanks
/ RCR 1860 help
I have the manual--it"s worthless
thanks
/ RCR 1860 help
Whoever came up with the chain an bottle jack method I read about on here has my vote on how to remove the stump jumper. It works, plain and simple. Now, the jumper has a slight wobble, any Ideas on how to true it up? Doesnt wobble much but you can feel it at pto speed--thats why I took it off in the first place. It;s not beat-up and looks good except fot the wobble. Could a machine shop fix it? Don't want to buy a new one if I don"t have to. Are all blade carriers welded to the stump jumper? Mine is.
Thanks
/ RCR 1860 help #8
Trying to tighten nuts holding gearbox to the deck. Stump jumper was a PAIN. I used Kroil, sledge, torch, bottle jack and chain as well as wooden wedges driven under pan and wetted for expansion, gear puller. It would not bulge.
Then I had an epiphany..... drilled a 1 inch hole through the pan to access nuts holding gearbox to deck. It was easy-greasy
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
MacDon 963 Draper Header (A63688)
MacDon 963 Draper...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
