RCK60B- 22BX Mower deck height adjustment problem
   / RCK60B- 22BX Mower deck height adjustment problem #11
Can you elaborate? I know next to nothing about Kubotas. Maybe, if it was green, I could figure it out. Take them loose from where?
Wouldn’t adjusting the rear (or front, for that matter), adjust the other some by default?
   / RCK60B- 22BX Mower deck height adjustment problem #12
Pull the spring loaded pin as if you are removing mower. This clears the threaded rod part, then turn to raise or lower.
Reinstall pin.
   / RCK60B- 22BX Mower deck height adjustment problem #13
Reinstall pin.
What exactly do I turn? The threaded rod? Is counterclockwise a longer cut.
2013 Fiat 500 Sport Hatchback (A56859)
2013 Fiat 500...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
Central Machinery Horizontal/Vertical Bandsaw, S/N 366852447, 120 Volt (A59076)
Central Machinery...
