Mowing rck60-29b deck shield
/ rck60-29b deck shield #1
taos
canada
kubota b2920
I have a rck60 -29b deck and the shield on the deck can only be lifted 3 inches or 10 degrees or less is this normal ? my old rck54 the shield on my bx25 was capable of lifting over 90 degrees the rck60-29b decks shield hits a bolt on cutting deck and this bolt inteferes with the shield from lifting up .Do I have the wrong shield ?or do I have to cut the shield were the bolt contacts the shield.
/ rck60-29b deck shield #2
Does your shield look like this ? ;
yes thats the same as mine
/ rck60-29b deck shield #4
Is the bolt holding something? If not holding something why not remove? Can the bolt be removed, turned over to improve clearance if holding something?
The bolt is holding a baffe in the front of the cutting deck ,and i don't know if it makes a difference. I do have the bagger on rear of 3point from kubota and i'm wondering if i have the baffe there because of bagger.
I' m going to take a picture and add this later
Here is pictures of my deck notice were the bolt is and is this a extra part (baffe) on cutting deck? I have a bagger I think this baffe is for bagger the bolt holds the baffe in place. do I just cut the chute deflector around bolt?seems kinda funny they would not modify the deflector for a bagger attachement at kubota
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2021 CAT 299D3xe Skid Steer w/ 2021 CAT HN415c Mulching Head (A62613)
2021 CAT 299D3xe...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2016 Ford F-150 Pickup Truck, VIN # 1FTEW1EG0GKE69622 (A65563)
2016 Ford F-150...
