RC gear oil overfill
/ RC gear oil overfill #1
TomIre
College Grove, TN
Branson 3725
Had my RC in it's side to sharpen blades and while it was there I drained the old gear oil out. Then filled it back up. It is a Big Bee RC and the drain bolt hole is high and on the side of the gear housing.
Happened to come across the manual and it says "Caution do not overfill". 1) how do I know what correct fill is? I just filled it until it started dripping back out. And, 2) what could possibly happen if it is "overfilled"? I can't see anything bad happening i do tend to put my hand on the gear housing (yes, everything is off) to check for excess heat/friction from time to time and no issues.
/ RC gear oil overfill #2
Overfilling can cause pressure to build up in the case, and can blow out seals or actually split the case.
/ RC gear oil overfill #3
Unless the unit has a fill plug and a check plug or dip stick (to check for correct fill ) - with the unit siting in operating position on flat, level ground - - fill until the gear oil come back out the fill plug hole. Biggest problem with overfill could be build up of internal pressure and blow a seal.
Surprised the Op Manual does not tell how to check fill level and what is the correct fill level. Read it carefully again. Call service techs at dealership where unit was purchased.
INTERNATIONAL 4900 GRAIN TRUCK (A63291)
INTERNATIONAL 4900...
2022 John Deere 612R Sprayer (A63111)
2022 John Deere...
2011 Honda Civic Coupe (A61574)
2011 Honda Civic...
Volvo EC220EL (A60462)
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
