RB-1560 Blade
/ RB-1560 Blade #1
valkyrie9901
Adrian, Michigan
Kubota BX-25D
Would an RB-1560 blade be too much weight out back for a BX-1500 tractor? Have one from my old BX-2200 and have just got a BX-1500 from my dad as he has just passed away. Thanks.
/ RB-1560 Blade #2
Sorry for your loss... I think a BX would handle the 5ft blade. If not, you could always cut it down.
/ RB-1560 Blade
I have noticed an RB-05 is #143 and an RB-15 series is #248. My BX2200 pulled it fine and also wondering if the class1 hitch is the same on both models? Thanks....JB.
/ RB-1560 Blade #4
5 footer no problem. I use a 6 ft Rankin with out issue on my BX.
/ RB-1560 Blade #5
No the hitches are different. One is a 0/limited 1 and the other just a 1.
/ RB-1560 Blade
Going to use the RB1560 on the BX1500 and see how it handles it. If it is too much, I will see if I can swap someone for a 48" blade. Thanks for the responses............JB.
/ RB-1560 Blade #7
If it was too heavy, I'm wondering if you could put some holes in it to lessen the weight. It still should do the job, I think.
/ RB-1560 Blade
The manual said #400 lbs. on the rear lift points and 54" blade width for the 1500. May shave 3" off each end and make it lighter rather than swiss cheese it....Thanks for the idea......JB.
/ RB-1560 Blade #9
What Id do is draw a vertical line, then cut it with a sawzall.
/ RB-1560 Blade #11
Sounds good to me... I was planning to do the same when I picked up a used 72in blade but I tried it first and it is working for my needs. There has been a few times the 'tail starts wagging the dog'. Someday I may trim it to 60in but I like the fact that it clears my rear tires even with it offset. I don't have to get too close to the ditch.
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
MISC PARTS (A63291)
MISC PARTS (A63291)
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
