Raytgal
/ Raytgal #1
raytgal
I recently obtained a Kubota that I was told was a B1600. I am trying to get all information I can about it. The dealer gave me a I&T K-201 shop manual and said I should use the info on the B6100D as this is the closest US crossover. Does anyone know for sure? I would like to obtain a parts manual. The problem I'm having a this time is - Just a couple weeks ago I had to replace one of the rocker arms that had snapped off. It was running fine for a little while and then started running bad again. This time I found that the rocker shaft had broken on the back end (by the last rocker). I had adjusted all the valves and it appears to be getting a lot of oil up there.
Any suggestions?
/ Raytgal #2
I can try to get you a parts book from Japan.
Unused 2025 CFG Industrial XZ20R Mini Excavator (A59228)
Unused 2025 CFG...
2017 Nissan Altima 4 door (A61306)
2017 Nissan Altima...
Kubota LX2620 (A53317)
Bobcat E42 (A60462)
Bobcat E42 (A60462)
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
154 (A52708)
154 (A52708)
