Raul5452
   / Raul5452 #1
Raul5452
Bronze Member
Corpus Christi Texas
John Deere 970, Kubota M7060
Toe in on a M7060. Purchased on 2017. I'm getting some playing in steering on street driving in high range. I'm at 2000 hours. Manual recommends toe in adjustment. Do I just turn front wheels as straight forward as I can visually ? Then what points do I use for accurate measurements ? Do I adjust both sides tie rods ? Appreciate any help.
   / Raul5452 #2
Your OP manual also tells you HOW to make any adjustments. When I check the toe-in/toe-out, it takes two people. Measure across the tractor. Distance across from front of front rims vs distance across from rear of front rims.
   / Raul5452
Thank you Oosik, I referred to op manual gives me tolarance, tells me to measure center of tire to center of tire. But it seems to me that I shouldn't just take out the difference from one side only or am I wrong ? I've be wrong many times before. lol. Manual does not give details how much to adjust on each side. Just a .008" to whatever. I don't remember the other dimension.
   / Raul5452 #4
You must toe each side equally. I suspect your tie rods are shot instead, If they rotate (end) easily, time to replace.
   / Raul5452
Thank you 5030, really appreciate the info. Tie rods are good and solid. I will give it a go.
   / Raul5452 #6
No matter how it plays, always make sure the inner joint boots are intact and grease tight. The inner joint, because it's a radial joint is about 5 times as expensive as the tie rod ends and is only a dealer item.
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
2006 MACK CV713 KILL TRUCK (A52472)
2006 MACK CV713...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
Polaris Side by Side (A50324)
Polaris Side by...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
