rattle
/ rattle #1
kenmac
Super Member
The Heart of Dixie
McCormick CX105 Kubota MX 5100 HST,
Just wondering if all mitsubishi Rattle ?
Neighbor just bought a new Mahindra tractor 35 hp.
I went up to see it. He cranked it and that engine rattled louder than my 07 cummins.
I had an old yanmar 3 cl. that I thought was loud, but this engine is louder that my old yanmar !
This engine is a lot louder than my kubota ! He' going to need hearing protection when he's using that tractor !
/ rattle #2
A diesels rattle. The loudness depends on the shape of the combustion chambers and the base compression ratio. You want to hear a loud one... If you can find a Cat 1693, they sound like they have ball bearings rattling around inside them.
Both my Kubota's rattle pretty loud when cold but quiet down somewhat when they warm up. I like the sound actually. Tells me they are making power.
/ rattle #3
Most newer ones don't rattle. The new Chevy pickups you can't even hear running. My 5090 isn't loud at all. My old 5310 was a very quiet tractor.
/ rattle #4
Couple possibilities: If it is in fact new, like brand new with few hours, it will rattle louder than after it breaks in.
Could also have an assembly defect, like something loose causing a loud rattle or possibly a loose or broken mount.
Could have a defective injector, causing a misfire or imbalance between the injectors.
I just fixed a horrible rattle on my M135X. It was an exhaust pipe rubber isolator bushing that had gone bad. Made the engine sound awful.
/ rattle #5
I have a Mahindra 4510 and a Yanmar 336d. I never thought they sounded really any different than most diesels.
/ rattle
If there's something wrong, the dealer didn't say anything. He just got it home when I was there.
Sounded like the valves were going to come out of the engine !
/ rattle #11
Then it would have to be a 1635. It's a mitsubishi tractor but the engine is made by Mahindra. Biggest mitsubishi tractor from Mahindra with a mitsubishi engine is the 1626.
/ rattle #13
Common rail injection engines are quieter than the older style direct injection engines.
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
2023 JCB 3TS-8T TELESKID (A65053)
2023 JCB 3TS-8T...
WeeDoo (A66738)
WeeDoo (A66738)
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
2018 INTERNATIONAL LT625 (A67714)
2018 INTERNATIONAL...
213088 (A64276)
213088 (A64276)
