Rattle from loader joystick - CK2620
   / Rattle from loader joystick - CK2620 #1
looch
QC, Canada
CK2620 SE Cab
Just about to tick over 20 hours and I've been "tolerating" a rattle coming from the loader joystick. It only happens at a certain engine rpm/frequency and I only have to touch the handle to make it stop. I finally had enough and decided to take a little sniff to see if it was just something minor I could patch up myself:
Well look at that - missing a spring behind a third function button. What are the chances they can supply the spring alone?
   / Rattle from loader joystick - CK2620 #2
Surely you can find a compatible spring or two in your leisure time after you have that replaced under warranty?
I wouldn't expect them to sell that spring, but I would imagine it's an off the shelf component.
   / Rattle from loader joystick - CK2620 #3
Maybe your dealer has a mobile tech that can replace it on-site, or could provide you with the whole assembly, allowing you to avoid downtime?
I sent the picture to the dealer and reassembled it. We'll see what comes of it.
The purpose of the post was to inform those that may find themselves in the same situation (unlikely as it may be).
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
2020 KENWORTH W990 TRI AXLE DUMP TRUCK (A54607)
2020 KENWORTH W990...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2016 Chevrolet Malibu Sedan (A55853)
2016 Chevrolet...
