Ratchet Rake on BX2660
   / Ratchet Rake on BX2660 #1
ronboDFA
Loretto MN
BX2660, SC2450
Anyone have experience using a ratchet rake on a BX? I'm looking to clear out an acre of 3/4" saplings for food plots.
   / Ratchet Rake on BX2660 #2
I have on a BX25, B3200, L3240 and currently on a B2620 (same RatchetRake I used on the BXs, the one on the L was different one/bigger). The RR is one of my most used implements that I won't sell until I sell my tractor and maybe still wouldn't sell it until I had already rec'd a replacement for it.:D The Pirinia will also do it but it doesn't have the lower teeth for finish work like the RR. I have done some brush cleaning with the RR but use it on a regular basis using the lower finer teeth for finish leveling ready for seed. Sure Piriniah supports will give their input and I've never used on but I have owned 2 RRs and currently own one which I won't go without.
Do search on Have you ever used the RatchetRake for lots of information.
   / Ratchet Rake on BX2660 #3
Thanks, JT. I need to order one through my local TSC store - they don't offer it in-store nor online (didn't sell enough fast enough) but they'll order it in @ $300. planting new yard, have a homemade spike drag to put some furrows in the dirt, but not very handy dragging it by chain where you need it; the RR sounds exactly what I'm looking for.
   / Ratchet Rake on BX2660 #4
For one tool to make food plots go with the RR. It will remove brush and prep the ground.
The Piranha is a great tooth bar for digging and also removes brush, etc
Thanks for the input, I'm going with the RR. I have been taking out the 3/4" dia. aspen saplings with a walk behind brush mower which works great but is hard on the 55 year old operator. I hope that the RR will help reduce the time spent behind the walk behind.
   / Ratchet Rake on BX2660 #6
I also have one it is a very handy tool and very well made. I am sure you will find uses for it that you never knew about.
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
