Ratchet Rake on BX2660
   / Ratchet Rake on BX2660 #1
ronboDFA
Loretto MN
BX2660, SC2450
Anyone have experience using a ratchet rake on a BX? I'm looking to clear out an acre of 3/4" saplings for food plots.
   / Ratchet Rake on BX2660 #2
I have on a BX25, B3200, L3240 and currently on a B2620 (same RatchetRake I used on the BXs, the one on the L was different one/bigger). The RR is one of my most used implements that I won't sell until I sell my tractor and maybe still wouldn't sell it until I had already rec'd a replacement for it.:D The Pirinia will also do it but it doesn't have the lower teeth for finish work like the RR. I have done some brush cleaning with the RR but use it on a regular basis using the lower finer teeth for finish leveling ready for seed. Sure Piriniah supports will give their input and I've never used on but I have owned 2 RRs and currently own one which I won't go without.
Do search on Have you ever used the RatchetRake for lots of information.
   / Ratchet Rake on BX2660 #3
Thanks, JT. I need to order one through my local TSC store - they don't offer it in-store nor online (didn't sell enough fast enough) but they'll order it in @ $300. planting new yard, have a homemade spike drag to put some furrows in the dirt, but not very handy dragging it by chain where you need it; the RR sounds exactly what I'm looking for.
   / Ratchet Rake on BX2660 #4
For one tool to make food plots go with the RR. It will remove brush and prep the ground.
The Piranha is a great tooth bar for digging and also removes brush, etc
Thanks for the input, I'm going with the RR. I have been taking out the 3/4" dia. aspen saplings with a walk behind brush mower which works great but is hard on the 55 year old operator. I hope that the RR will help reduce the time spent behind the walk behind.
   / Ratchet Rake on BX2660 #6
I also have one it is a very handy tool and very well made. I am sure you will find uses for it that you never knew about.
2019 KUBOTA KX057-4 EXCAVATOR (A51246)
2019 KUBOTA...
2015 Dodge 5500 4X4 Bucket Truck (A53472)
2015 Dodge 5500...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
7022 (A50322)
7022 (A50322)
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
