ranch vehcile
/ ranch vehcile #1
bobs
usa
i need a ranch vehicle. it needs to be able to tow a small tralor and go up atleast 300 foot hills 90 degres up are the rtv's any good? I need it to carry loads up hills.
/ ranch vehcile #2
bobs
The RTV can do all you're requesting. So can most others.
How steep are the hills? Primarily, will you be carrying loads up or down hills?
For towing, you'll find many of us hauling several thousands of pounds on trailers with the RTV and loading with 1200-1500# in the RTV's box. So far, no reported problems.
My hill is about 1000' deep but goes up over 300' of elevation in that distance. I can use trails that traverse the hill but have yet to find ANY machine that can go straight up.
If a true work horse is what you're looking for, the RTV is pretty near the top. If you want to work and play, there's several that are faster but pretty powerful as well.
I'd suggest you pull up a beverage of you choice and pick through some of the more recent posts in this forum. You'll find all kinds of input on the RTV as well as some comparisons and input on the Ranger, Rhino, Gator...
Brian
PS. Please fill out your profile so we know a little more about you. A general idea of where you live is a big help. It helps to consider the ground (sand, clay, rocks..., terrain, snow, etc.)
/ ranch vehcile #4
</font><font color="blue" class="small">( i need a ranch vehicle. it needs to be able to tow a small tralor and go up atleast 300 foot hills 90 degres up are the rtv's any good? I need it to carry loads up hills. )</font>
bobs,
Your edit added the 90 degrees and sentence to carry loads up hill.
like rockinmywaypa said, 90 degrees is straight up. Please clarify.
/ ranch vehcile
more like 52 degres
/ ranch vehcile #6
bobs,
Only have second to figure this out but here's what I come up with.
52 degrees gives a slope of approx. 1.25.
That means for every 40' horizontally into this hill, the elevation rises 50'.
If this is in fact the case, I don't think any tractor, UTV and probably 90% of ATV's couldn't climb up the hill.
Do you have any pictures you can post of this hill?
Brian
/ ranch vehcile #8
I Played around with a rental RtV today, and I would dare say we scaled some stretches of 45 degrees. The salesman was a former rally driver and he took the helm for the trecherous stuff. He was a little disappointed that we didn't get stuck. We did most of the stunts with about five hundred pounds of firewood in the back. I was satisfied, so mine will be here before turkey day!
/ ranch vehcile #9
whoodle,
Congrats on your new purchase!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
How much distance did you go at 45 degrees? Mine bogs down if you try relatively steep hills that go on for a good duration.
/ ranch vehcile #10
I walked some of the areas today, to confirm my claim, and see the real deal. First of all the, the damage was pretty minimal considering the rocks and trees. the Rtv bottomed out many times and caught up on rocks and trees. We had the chainsaw so we could cut trees if need be. I would say that the 45 degrees were limited to 25 feet where a run up was clearly necessary. However, we went up slopes of more than 30 degrees for long enough that the run in was no factor. I walked one area with a friend of mine and he was definitely impressed. Additionally, I tried backing up a slope of perhaps 35 degrees that I was not able to get a start on, but with a little run up I mounted. the rental P-brake was too loose, so the rig crept back down while I was clearing the trail. I probably will never take my RTV on such a mission because ther is no need, but a rental with a willing salesman?...
/ ranch vehcile #11
Well, measuring slope angle is tricky unless you have a device to measure it with...30 degrees is very steep and 45-52 is borderline insane steepness to be driving around on. I'm willing to bet if you measured these slopes with the proper devices you would find they are not as steep as you think by just looking at them.
/ ranch vehcile #12
As a matter of fact, I did measure the angles. My driveway has a 100 foot stretch which rises about 25 feet. I call that a 23% grade just to be safe. The steps in my barn are 10 inches by ten inches. I call that a 45 % slope. In the winter I have soiled many undergarments on the driveway, especially because there is a 180% turn at the bottom of one of the grades.
/ ranch vehcile #13
</font><font color="blue" class="small">( My driveway has a 100 foot stretch which rises about 25 feet. I call that a 23% grade just to be safe. )</font>
Actually it is closer to a 26% grade, or approximately a 14.5 degree incline.
</font><font color="blue" class="small">( The steps in my barn are 10 inches by ten inches. I call that a 45 % slope. )</font>
That would be a 45 degree incline, or a 100% slope.
/ ranch vehcile #14
Thanks on the terminology.
I would say the areas that were close to 45% incline were of less than 15 feet driven not horizontal. In addition, I would say the slope was closer to the 10/12 pitch of my barn than the incline of my stairs. When I get my rtv I'll break out the builder's level and get a reference.
/ ranch vehcile #16
</font><font color="blue" class="small">( I would say the areas that were close to 45% incline )</font>
Do you mean a 45 degree incline or a 45% grade??? /forums/images/graemlins/crazy.gif
/ ranch vehcile #17
It seems like the tilt meter would read 40-45.
/ ranch vehcile #18
Here's an incline for ya.
Unused 2021 HLA 20LA04504 Concrete Chute Bucket Skid Steer Attachment (A66734)
Unused 2021 HLA...
AGT LRT23 (A64912)
AGT LRT23 (A64912)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2008 THE MACHINE CO. THAWZALL H250 HEATER  (INOPERABLE) (A68842)
2008 THE MACHINE...
2012 PETERBILT 337 FLATBED W/ LIFTGATE (A67714)
2012 PETERBILT 337...
2016 VOLVO A40G OFF ROAD DUMP TRUCK (A65056)
2016 VOLVO A40G...
