Ran over twig, now tractor won't move
   / Ran over twig, now tractor won't move #1
rondele
great falls, va
JD LA140
Yesterday my wife was cutting grass with our L140 and didn't see a small twig. After she ran over it and intended to continue, it would not move. She disengaged blades, shut off engine and saw that part of the twig was around one of the pulleys.
After removing it and restarting tractor it still would not move. We managed to put it up on a lift but couldn't see anything amiss.
Appreciate any advice!
   / Ran over twig, now tractor won't move #2
Must resist JD joke...must resist JD joke...must resist JD joke.
Sorry you're dealing with this. When you have it off and on the lift, can you freely move the belt/pulley?
  • Good Post
Reactions: JJT
   / Ran over twig, now tractor won't move #3
Did you happen to check the top of the deck to see if it thru the belt off the pulley?
And maybe check the safety switch(es) in case the branch struck one of those wires before getting wrapped around the pulley.
Yes, while it was on lift we were able to move belt and blades. Also when pushing down on pedal noticed the tension was much less than normal.
   / Ran over twig, now tractor won't move #5
Are you aware there is a belt to move the tractor which is separate from the one that drives the blades? Check the path carefully.
Belt was on pulley and checked the safety switch under seat, it was securely connected
Yes, both appeared OK but will check again after we get it back on lift
   / Ran over twig, now tractor won't move #9
Some riding lawn mowers have a little lever, often at the back of the tractor you pull out so the tractor can be pushed or towed. Any chance yours has such a lever and it got pulled out?
Rod was pushed in all the way (until we pulled it out to get it into shed!)
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2014 Ford F-550 XL (A50120)
2014 Ford F-550 XL...
2017 John Deere 6120E 120HP 4WD Agricultural Tractor (A50322)
2017 John Deere...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
