Loader Rams turned 180?
/ Rams turned 180? #1
rdinatal
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
While I was done some dirt work Saturday I was noticing... There is a lot of dirt, dust, crud spilling over the bucket and getting on the hydraulic rods. Why the rods down towards the bucket? Has anyone turned them around and swapped the hoses?
This will keep the rods and seals away from crap. Less contamination and seal issues.
-R
/ Rams turned 180? #2
I think if you turn them around the cylinder end with the hoses will move to much .....
/ Rams turned 180? #3
I think the chances of damaging the base end hose & fitting would have a greater chance of happening than "nicking" the exposed end of the cylinder if it were reversed. :2cents:
/ Rams turned 180? #6
Dirt bikes have shields to protect the stanchions and seals from rocks and dirt. Weld up some shields and mount them over the stanchions. All it would take is a length of sheet steel bent lengthwise at about a 45 deg angle and some brackets to mount them. Or...don't pick up an overflowing bucket load. :thumbsup:
/ Rams turned 180? #7
Spill shields ? are a good way to keep the cyl. & pins somewhat clean & protected. Not a big deal to fab up.
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
DYNAPAC CC524HF DOUBLE DRUM ROLLER (A64279)
DYNAPAC CC524HF...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
